Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 04:55PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 31, 2014 11:22AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 02, 2014 12:08PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 02, 2014 12:25PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 02, 2014 01:01PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 02, 2014 01:20PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 03, 2014 05:27AM |
dc42
There is so much backwash from the fan that when I first assembled my Ormerod, I thought the fan was running the wrong way. A fan inlet duct greatly reduces the backwash and may also make the fan more efficient. You can find the one I use (based on a design by kwikius) here [github.com].
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 03, 2014 05:46AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 04, 2014 01:16PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 04, 2014 02:57PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 04, 2014 06:12PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 05, 2014 03:27AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 05, 2014 08:51AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 05, 2014 09:13AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 05, 2014 12:02PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 05, 2014 04:14PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 05, 2014 07:34PM |
dc42
Hi Sampling, when using the one-piece duct, you need to rotate the heatsink 90 degrees and drill an extra hole in it for one of fhe mounting screws. Looking at your photo, I'm not sure you have done that because I can't see the original mounting hole that becomes unused.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 06, 2014 07:49AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 06, 2014 08:52AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 06, 2014 10:22AM |
appjaws1
PS I'm not clear how to set up the Ormerod to zero X by IR but do bed compensation by ultrasonic.
What do I need to enter and in which files.
I apologise if you have already outlined this, perhaps I missed it, after all I have been very confused over the last few days. :-
G91 G1 Z5 F200 G90 M558 P1 ;***************** G1 X-240 F2000 S1 G92 X0 G1 X3 F200 G1 X-10 S1 G92 X0 G91 G1 Z-5 F200 G90 M558 P3 ;*******************
M558 P1 ; select IR G31 Pxx Zxx ; set IR G31 parameters M558 P3 ; select ultrasonic G31 Pxx Zxx ; set ultrasonic G31 parameters
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 06, 2014 10:33AM |
Davek0974
I.R. Board is fitted and works brilliantly, nicely set the z zero on multiple tests, LEDs are good too, plus the fan on/off, a great mod to the machine.
One little snag I have is that I calibrated it to z1.0mm in the config.g file, I think the P was about 380, anyway, I usually set z at the thickness of a sheet of paper or about 0.1mm as zero, my first print got off to a lumpy start with the head bobbing up and down after a few layers, I am guessing head is too close to bed??
If I alter the value in config.g to 0.9mm will this raise it by 0.1mm and set that as zero?
Other than that, it's the first time I have homed all axes at once and also run a successful auto bed compensation!
Nice one
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 07, 2014 01:13PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 07, 2014 04:46PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 07, 2014 04:58PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 07, 2014 05:23PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 11, 2014 03:38PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 11, 2014 03:51PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 11, 2014 04:13PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 11, 2014 06:08PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? April 11, 2014 06:45PM |
Prices inc. carriage UK EU EuNV Outside EU Bare board £ 7.34 £ 8.36 £ 6.97 £ 7.65 Kit 2 fully soldered £22.84 £30.24 £25.20 £26.00 Kit 3 £25.84 £33.24 £27.70 £28.50 Kit 3 fully soldered £31.84 £39.24 £32.70 £33.50 Kit 4+ £43.84 £51.24 £42.70 £43.50 Kit 4+ fully soldered £49.84 £57.24 £47.70 £48.50 Kit 5 £52.84 £60.24 £50.20 £51.00 Kit 5 fully soldered £58.84 £66.24 £55.20 £56.00
