Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 08:59AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 09:04AM |
stevelup
dc42, could you please let me know where I can find a mechanical drawing of the ultrasonic transducer.
I'm going to design a mounting bracket for it, but could do with accurate dimensions.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 09:05AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 10:00AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 02:21PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 26, 2014 06:54PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 09:18AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 11:47AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 11:54AM |
gammasistemi
In your hothend airduct there are only two holes for the airflow, but in the original ormerod part there are 3 holes.
When i tested Matt's solution, i had some issues when printing long parts or bridges over the y axis, this because the central hole is important to cool the PLA.
The same part printed with the original duct was better.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 03:29PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 03:36PM |
Davek0974
Just printed the duct, might not fit it yet if it needs modifying
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 03:53PM |
dc42
Davek0974
You don't have to use the one-piece duct with my sensor board, because johneato has kindly provided a variation on the standard 2-piece duct to include mounting holes for the board.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 04:01PM |
Davek0974
dc42
Davek0974
Ooh, nice, where would that be located please?
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 04:05PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 05:07PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 27, 2014 08:45PM |
DCQuote
DC42
The new files are in the usual place [github.com]. You may need to extend the x-homing tab a little further in the +x-direction so that the IR sensor sees it before the insulator stops against the z-nut trap. I put an oversized piece of white sticky label on top of mine.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 28, 2014 10:02AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 28, 2014 02:37PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 28, 2014 02:43PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 06:15AM |
which way should the fan be blowing?! I am still using the originally supplied fan and rewired it exactly as per the instructions, but now the fan appears to be pulling air out wards (i.e. Away from the heat sink ) rather than blow it into the heat sink as I could have sworn it was doing previously - can someone please put me right, as I'm refraining from printing until I'm sure
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 06:25AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 06:42AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 07:13AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 11:49AM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 02:29PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 03:29PM |
- adjusting H to -36 corrected my ambient temperature and now causes a temperature reading of 2000 when thermistor is disconnected and gives the error message - thank you
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 03:44PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 04:01PM |
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 04:27PM |
dc42
Hi MrCrispi, if you are getting 2000C with the thermistor disconnected, your H value is too far away from zero. Try H-35 or H-34 etc. until you get a -273 reading with thermistor disconnected.
Re: Anyone interested in a modulated IR sensor + fan control + illumination board? March 30, 2014 04:36PM |
