Why 0.24mm layer thickness? February 20, 2014 01:03PM |
Re: Why 0.24mm layer thickness? February 20, 2014 01:21PM |
Re: Why 0.24mm layer thickness? February 20, 2014 01:45PM |
Re: Why 0.24mm layer thickness? February 20, 2014 04:54PM |
#define DRIVE_STEPS_PER_UNIT {87.4890, 87.4890, 4000.0, 420.0}
Re: Why 0.24mm layer thickness? February 20, 2014 05:52PM |
Re: Why 0.24mm layer thickness? February 20, 2014 06:18PM |
Re: Why 0.24mm layer thickness? February 20, 2014 09:33PM |
rayhicks
No, the firmware doesn't, it's more the physics of the motor that make it happen, it can't hold between a "step", though it can be told to move there, it won't necessarily, and might move after two or three microsteps to the fourth microstep position, then flip back when not microstepped again - and indeed microsteps aren't as even as full steps (and full steps have a reasonably large variance).
Re: Why 0.24mm layer thickness? February 21, 2014 05:25AM |
Re: Why 0.24mm layer thickness? February 21, 2014 06:47AM |
Re: Why 0.24mm layer thickness? February 21, 2014 07:48AM |
Re: Why 0.24mm layer thickness? February 21, 2014 09:40AM |
Re: Why 0.24mm layer thickness? February 21, 2014 09:46AM |
Mr.Lupastr
I am "greenhorn" and with interesting following this forum.
By suggest rayhicks I have done little test with printing .
Results are in attachment.
Left print have Layer height = 0.24mm and right 0.5mm (more then twice ).
Thickness 0.24 or 0.25 probably will not be great difference
Lubos
Re: Why 0.24mm layer thickness? February 21, 2014 10:58AM |
Re: Why 0.24mm layer thickness? February 21, 2014 12:14PM |
Re: Why 0.24mm layer thickness? February 21, 2014 12:36PM |
Re: Why 0.24mm layer thickness? February 21, 2014 01:59PM |
rayhicks
@dave -not sure, I guess that it's slowing down quicker then getting the hell out of there faster - give it a try (I didn't increase the speed, just the acceleration.).
on the extrusion thing, if you extrude into air, the filament comes out at nozzle diameter then (depending on flowrate and temperature) it swells a little ( I did this the other day with a fairly fast extrude of PLA at 185, 195 and 205 I got a change from around 1.0 mm at 185 °C down to around 0.6 at 205.
Re: Why 0.24mm layer thickness? February 21, 2014 02:18PM |
Re: Why 0.24mm layer thickness? February 22, 2014 05:14AM |
