First parts analysis.... March 02, 2014 12:46PM |
Re: First parts analysis.... March 02, 2014 01:48PM |
Re: First parts analysis.... March 02, 2014 02:29PM |
Re: First parts analysis.... March 02, 2014 02:34PM |
Re: First parts analysis.... March 02, 2014 03:14PM |
Re: First parts analysis.... March 02, 2014 03:24PM |
Re: First parts analysis.... March 02, 2014 03:36PM |
Re: First parts analysis.... March 02, 2014 03:38PM |
Re: First parts analysis.... March 02, 2014 04:24PM |
Re: First parts analysis.... March 02, 2014 04:34PM |
Re: First parts analysis.... March 02, 2014 04:40PM |
Re: First parts analysis.... March 02, 2014 04:47PM |
Re: First parts analysis.... March 02, 2014 04:51PM |
Davek0974
As for prototypes, err, dunno, haven't even learnt 3d cad yet sad smiley
Re: First parts analysis.... March 02, 2014 04:52PM |
rayhicks
LOL funny you chipped in just then Erik, I was busy looking up your all-metal spool holder to give Davek something to aim at And here it is : [forums.reprap.org]
Cheers
Ray
Re: First parts analysis.... March 03, 2014 05:00AM |
Re: First parts analysis.... March 03, 2014 05:05AM |
Re: First parts analysis.... March 03, 2014 06:20AM |
GregL
I made the Bearing with herringbone gears as a test piece some time ago.
I have since thought of using it as a bearing for a spool mount (horizontal) - so I printed a base to fit through the sun gear (a bit too small diameter), and a spool holder to fit over the bearing
Re: First parts analysis.... March 03, 2014 06:40AM |
Re: First parts analysis.... March 03, 2014 10:07AM |
rayhicks
Davek0974
If you're at all into scripting or programming, openScad is pretty powerful and although it doesn't let you do much mouse stuff, what you ask for is what you get - well worth a try www.openscad.org
Ray
Re: First parts analysis.... March 04, 2014 04:18PM |
Re: First parts analysis.... March 05, 2014 01:01PM |
Davek0974
I reprinted the orthogonal test piece tonight following my bed rebuild, this time I sliced the stl in slic3r using the custom profile for ormerod with the added lines for temperature controls and waiting for warm up.
The result on the X and Y surfaces was much improved following the fitting of the two part Y belt tensioners, very clean and straight.
However, when it had finished I noticed some ridges or banding on the Z part, to the eye they appear to be about 1mm apart , very shallow but noticeable and were not on the first part which was pre-sliced. They only start at the point the vertical column starts to rise, the vase legs are perfect.
It's not critical but as it was not on the first run, I know it can do better
Can't really get macro photos with my phone so tricky to get a picture up.
Any pointers to check for?
Re: First parts analysis.... March 05, 2014 03:41PM |
dmould
Davek0974
What did you set your layer height to when you sliced it? If the layer height is not set to be an exact number of steps you will get a slightly uneven effect because some layers will have one step more or less than other layers due to the firmware rounding each Z height to the nearest step.
Dave
(#106)
Re: First parts analysis.... March 06, 2014 06:07AM |
Re: First parts analysis.... March 06, 2014 07:13AM |
Davek0974
dmould
It was default for the ormerod files, just checked and it's 0.4mm with first layer at 0.35mm
Is there a better setting?
Re: First parts analysis.... March 06, 2014 07:40AM |
Re: First parts analysis.... March 06, 2014 07:52AM |
Re: First parts analysis.... March 06, 2014 07:57AM |
Davek0974
no, slic3r was definitely set for 0.4 / 0.35mm
If the axis was slipping, it wouldn't be so precise surely, every 4 layers???
Re: First parts analysis.... March 06, 2014 02:30PM |
