Chuffed... March 14, 2014 04:14AM |
Re: Chuffed... March 14, 2014 05:35AM |
Re: Chuffed... March 14, 2014 06:57AM |
Re: Chuffed... March 14, 2014 09:39AM |
Re: Chuffed... March 14, 2014 09:48AM |
Re: Chuffed... March 14, 2014 10:14AM |
GregL
OK guys: Now explain Minkowski to me. I was unable to understand the OpenScad explanation...
Greg
Re: Chuffed... March 14, 2014 11:02AM |
Re: Chuffed... March 14, 2014 03:43PM |
$fs=0.8; // default 1, 0.2 is high res $fa=4;//default 12, 3 is very nice %translate([0,0,-0.5])cube([200,200,1],center=true); //build platform
Re: Chuffed... March 14, 2014 04:09PM |
Davek0974
It's a powerful little program that's for sure
Re: Chuffed... March 15, 2014 03:52PM |
Re: Chuffed... March 17, 2014 12:10PM |
Davek0974
Hmm, odd, I needed a slightly larger version of my motor cover so I simply expanded the inner and outer boxes in openscad but it's printing now and one side of the box is being printed without infill, just two walls?
I have also today updated to dc42 firmware and also to the RRP python pronterface so it could be anything but has anyone had this before.?
Luckily I don't think it will matter much but it's annoying.
Re: Chuffed... March 17, 2014 02:13PM |
Re: Chuffed... March 21, 2014 05:08AM |
Re: Chuffed... March 21, 2014 05:51AM |
Davek0974
....is that an adjustment or a test/adjusment I need to make somewhere in Slic3r????
Re: Chuffed... March 21, 2014 06:14AM |
Re: Chuffed... March 21, 2014 06:17AM |
Re: Chuffed... March 21, 2014 10:18AM |
Please elaborate.Quote
ormerod168
I think the drill is to print a single wall test and adjust the in Slic3r "extrusion multiplier" to that - afair mine is set at 0.79, default is 1.0
I used this one, you don't need to print it to full hight to measure of cause (and the print should be able to hold water over time if the print is perfect)
[www.thingiverse.com]
Erik
Re: Chuffed... March 21, 2014 01:54PM |
SlinBin
ormerod168
Erik
Ive been looking at threads and are still a little confused as to what settings other people use for this test.
do you print the "single wall test" as a single wall (spiral vase setting in sliz3e) or do you (everybody) just intend that it is printed with no infill (obvious as it is not a solid).
I suppose the latter but would like somebody to clairify this, or even more about the steps you take in the process.
Thanks ! not just regarding this but for all the other helpfull posts Ive read around the forum and not commented on ;-)
Re: Chuffed... March 21, 2014 08:17PM |
Re: Chuffed... March 26, 2014 03:47PM |
Re: Chuffed... March 26, 2014 07:52PM |
Davek0974
Did the thin wall test piece, very nicely too
Walls measured 0.54/0.54/0.53/0.53 which gives me an average of 0.535 so I set the extrusion multiplier to 0.5 / 0.535 = 0.934 does that sound logical?
