I have some serious problems with the printer. March 14, 2014 04:36AM |
Re: I have some serious problems with the printer. March 14, 2014 05:07AM |
Re: I have some serious problems with the printer. March 14, 2014 05:22AM |
Re: I have some serious problems with the printer. March 14, 2014 05:38AM |
Re: I have some serious problems with the printer. March 14, 2014 05:42AM |
Re: I have some serious problems with the printer. March 14, 2014 05:44AM |
jaro_p
Addition to the first point.
Too far away means that the system arbitrarily shift starting point in the Z-axis of about 1mm above.
Re: I have some serious problems with the printer. March 14, 2014 09:25AM |
Re: I have some serious problems with the printer. March 14, 2014 11:09AM |
dmould
Firstly, are you perhaps sending your print files via the USB interface? Your prints look similar to mine did before I realised that the compiled Pronterface USB interface is too slow and results in jerky movements. You must copy the G files to SD card and print from that. Just run "circle.g" first from the USB and then from the SD card and see the difference.(#106)
dmould
Secondly, replace the Duet firmware with DC42's latest. The official release has an acceleration bug that caused the stepper to miss steps occasionally when printing at fast speeds.(#106)
dmould
Have you set retraction to at least 4mm in Slic3r? The default of 1mm is too small and will produce blobbing and whiskers.
(#106)
Re: I have some serious problems with the printer. March 14, 2014 12:07PM |
Re: I have some serious problems with the printer. March 18, 2014 03:24AM |
Re: I have some serious problems with the printer. March 18, 2014 08:12AM |
jaro_p
Hey, thanks for the tip to run programs from the SD - card. This considerably improved prints.
Similarly, the reverse flow of 4mm Slic3r helped.
What I still can not resolve the position of the zeros in the Z - axis.
Deal with it while stopping the program at the beginning of the first layer, the zero adjustment
in the middle of the heat bed, then G92 Z0. Finally starting the program again.
