Re: first print not gonna happen June 19, 2014 08:55AM |
Re: first print not gonna happen June 19, 2014 09:16AM |
droftarts
I don't think you have imported our Slic3r profiles. See: [reprappro.com]
Also, the current 0.65e firmware can be set to absolute or relative extrusion.
Re: first print not gonna happen June 19, 2014 10:20AM |
Re: first print not gonna happen June 19, 2014 10:41AM |
Re: first print not gonna happen June 19, 2014 10:44AM |
Re: first print not gonna happen June 19, 2014 10:47AM |
Re: first print not gonna happen June 19, 2014 10:52AM |
Re: first print not gonna happen June 19, 2014 11:26AM |
Re: first print not gonna happen June 19, 2014 02:24PM |
Re: first print not gonna happen June 19, 2014 03:27PM |
Re: first print not gonna happen June 19, 2014 04:50PM |
Re: first print not gonna happen June 19, 2014 06:18PM |
VortyZA
I actually still have the same grinding problem with the x-axis. Added a limit switch (the original kit didn't have one) which mostly fixed it, but if the x axis is already at 0 then it just makes a horrible grinding noise when you home it. If I moved X in a positive direction, then homed X it would mostly work
I probably could have tried to solve the original issue, but was comfortable with the manual solution.
Re: first print not gonna happen June 20, 2014 04:03AM |
Re: first print not gonna happen June 20, 2014 05:35PM |
Re: first print not gonna happen June 20, 2014 05:59PM |
VortyZA
Don't mean to sound daft or noobish - been printing for a while now, but.. Explain white tape and the x-homing tab?
Re: first print not gonna happen June 21, 2014 07:59AM |
dc42
VortyZA
The x-homing tab is the little piece of plastic sticking out from the x-motor mount close to the threaded rod. It serves as the target for the IR sensor when homing the X axis. Depending on what P value you configure in your G31 command, the plastic may not reflect enough IR to trigger the IR probe, and then x-homing fails. Putting something reflective on top of the tab solves the problem. The current RepRapPro commissioning instructions suggest using a piece of silver foil.
Re: first print not gonna happen June 22, 2014 05:56PM |
