Re: Commissioning/ Problem with Establishing communication with the Duet April 10, 2014 07:29AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 11, 2014 02:53AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 11, 2014 03:11AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 11, 2014 02:27PM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 11, 2014 03:20PM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 11, 2014 03:46PM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 12, 2014 01:44AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 12, 2014 03:33AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 12, 2014 04:58AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 12, 2014 02:43PM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 15, 2014 01:51AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 15, 2014 08:00AM |
Bobb
Got my new board today and the first thing I did was that I went to a solder company to upgrade a pin for the heated bed so nothing can go wrong by putting the pins in different locations.so tonight I am on it again.
This was very easy and the guy who did it couldnt understand why this not was done from start. Well only company one can answer that.
Re: Commissioning/ Problem with Establishing communication with the Duet April 16, 2014 02:10AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 16, 2014 09:32AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 16, 2014 02:41PM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 16, 2014 02:59PM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 16, 2014 04:24PM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 17, 2014 02:25AM |
Sardi
Hi Bobb,
1) OPENING IN DOS USING COMAND PROMPT: go to START -> in the search box write CMD and click on it (if you are using WinXP go to - Programs - Accessories - Comand prompt) -> when a black DOS window opens it should just write C:/User/name of your computer (now you see my name)
enter the comand CD.. and hit enter
repeat the above command again and you will have only C:/
enter command CD temp -> that should get you IN your temp folder
enter command for the firmware update "bossac --port=COM4 -U true -e -w -v -b RepRapFirmware-XXX-DD-MM-YYYY.bin -R", and check in the Device Manager what the COM number for your Duet is.
2) SD CARD: Your SD Card MUST be a class 10, everything below that is too slow for Duet to read.
Hope this helps, let me know how you did.
Antonio
Re: Commissioning/ Problem with Establishing communication with the Duet April 17, 2014 06:24AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 17, 2014 06:32AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 17, 2014 07:15AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 17, 2014 07:28AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 18, 2014 01:38AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 18, 2014 03:45AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 18, 2014 04:42AM |
parper101
If only class 10 cards can be used why are reprap supplying class 4 cards? I have received a class 4 card as well. Upgraded to class 8 and that seems to work better.
Re: Commissioning/ Problem with Establishing communication with the Duet April 18, 2014 10:17AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 19, 2014 02:42AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 19, 2014 04:39AM |
Re: Commissioning/ Problem with Establishing communication with the Duet April 19, 2014 03:11PM |
