Replace PLA with solder? April 12, 2014 05:25PM |
Re: Replace PLA with solder? April 13, 2014 08:43AM |
Re: Replace PLA with solder? April 13, 2014 10:05AM |
Re: Replace PLA with solder? April 13, 2014 10:15AM |
Re: Replace PLA with solder? April 14, 2014 07:33AM |
Re: Replace PLA with solder? April 15, 2014 07:35AM |
Re: Replace PLA with solder? April 16, 2014 03:40PM |
Re: Replace PLA with solder? April 16, 2014 03:43PM |
Re: Replace PLA with solder? April 17, 2014 03:42AM |
Squags
If you look on youtube you'll see videos of people using solder in a 3d printer. The results seem pretty poor compared to plastic, but fun none the less. I've just persuaded my uni to pay for all the parts needed to design and build a hot end that'll (hopefully) melt aluminium wire. If successful I intend to make a hot end that can be used with reprap printers (along with an enclosure and argon supply). I only have until the beginning of October and with the Ormerod being my first machine, I may well try and make it retrofitable to the Ormerod - although many modifications are expected to be necessary.
Re: Replace PLA with solder? April 17, 2014 04:31AM |
Re: Replace PLA with solder? April 17, 2014 05:47AM |
Re: Replace PLA with solder? April 17, 2014 08:40AM |
Yes, this is one of my desired uses for producing bespoke silver jewellery and will be exploring this in the summer, along with 'press forming' for thin sheets of malleable metal.Quote
jstck
.... even when the desired material isn't directly printable, 3d printers are quite useful for making one-off molds for example.
