New firmware 058-dc42 and web interface 0.69 April 19, 2014 09:44AM |
Re: New firmware 058-dc42 and web interface 0.69 April 19, 2014 12:40PM |
Re: New firmware 058-dc42 and web interface 0.69 April 19, 2014 01:17PM |
Re: New firmware 058-dc42 and web interface 0.69 April 20, 2014 06:58AM |
Re: New firmware 058-dc42 and web interface 0.69 April 20, 2014 07:11AM |
Re: New firmware 058-dc42 and web interface 0.69 April 20, 2014 05:07PM |
Re: New firmware 058-dc42 and web interface 0.69 April 21, 2014 05:59AM |
Re: New firmware 058-dc42 and web interface 0.69 April 21, 2014 07:10AM |
Re: New firmware 058-dc42 and web interface 0.69 April 21, 2014 08:02AM |
Re: New firmware 058-dc42 and web interface 0.69 April 21, 2014 09:15AM |
appjaws1
David,
Just using your web interface 0.70, great facility to print directly from a sd temp file.
The progress is working well but the object height is showing at 5mm when in fact it should be 22mm, also the estimated print end time boxes are just reading 00:00:00.
Have I misunderstood should the height and time be working now?
Thanks for your efforts
Paul
Re: New firmware 058-dc42 and web interface 0.69 April 21, 2014 09:25AM |
Re: New firmware 058-dc42 and web interface 0.69 April 21, 2014 02:07PM |
Re: New firmware 058-dc42 and web interface 0.69 April 21, 2014 02:10PM |
Re: New firmware 058-dc42 and web interface 0.69 April 21, 2014 02:38PM |
Re: New firmware 058-dc42 and web interface 0.69 April 21, 2014 03:24PM |
Re: New firmware 058-dc42 and web interface 0.69 April 21, 2014 06:04PM |
Re: New firmware 058-dc42 and web interface 0.69 April 22, 2014 06:41AM |
Re: New firmware 058-dc42 and web interface 0.69 April 22, 2014 06:58AM |
Re: New firmware 058-dc42 and web interface 0.69 April 22, 2014 11:14AM |
Re: New firmware 058-dc42 and web interface 0.69 April 22, 2014 11:17AM |
Re: New firmware 058-dc42 and web interface 0.69 April 22, 2014 11:18AM |
Re: New firmware 058-dc42 and web interface 0.69 April 22, 2014 11:32AM |
dc42
Dave, you just need to use a M208 command in config.g to define the axis lengths. I use:
M208 X225 Y210
which is close to the maximum travel on my build.
Re: New firmware 058-dc42 and web interface 0.69 April 22, 2014 11:49AM |
Re: New firmware 058-dc42 and web interface 0.69 April 22, 2014 12:22PM |
Re: New firmware 058-dc42 and web interface 0.69 April 22, 2014 12:32PM |
dc42
The reason I use X225 is because X=0 on my build is about 25mm off the edge of the glass. If your build is similar to mine, then for Cura I guess you can either adjust the X home position by 25mm after homing (which I think is what you have already described), or pretend the X axis travel is 250mm.
Re: New firmware 058-dc42 and web interface 0.69 April 22, 2014 12:33PM |
Re: New firmware 058-dc42 and web interface 0.69 April 22, 2014 02:00PM |
Re: New firmware 058-dc42 and web interface 0.69 April 22, 2014 02:19PM |
