Connecting Ormerod Duet via ethernet to PC - Problem May 07, 2014 01:33PM |
Re: Connecting Ormerod Duet via ethernet to PC - Problem May 07, 2014 01:37PM |
Re: Connecting Ormerod Duet via ethernet to PC - Problem May 07, 2014 02:16PM |
Re: Connecting Ormerod Duet via ethernet to PC - Problem May 07, 2014 02:18PM |
Re: Connecting Ormerod Duet via ethernet to PC - Problem May 07, 2014 02:56PM |
Sardi
I would firstly check the IP addresses before anything else. Your router could have provided a different IP address than your PC does now.
Re: Connecting Ormerod Duet via ethernet to PC - Problem May 07, 2014 03:48PM |
Re: Connecting Ormerod Duet via ethernet to PC - Problem May 08, 2014 06:25AM |
Re: Connecting Ormerod Duet via ethernet to PC - Problem May 08, 2014 04:48PM |
Re: Connecting Ormerod Duet via ethernet to PC - Problem May 09, 2014 05:40PM |
dc42
I used to have the Duet connected by cable to a laptop, which was wirelessly connected to the router. To do this, I bridged the wireless and wired network connections. This is very easy to do under Windows: go to control panel->network connections, select both the wired and wireless adapters, right click and select Bridge. I didn't need to use a crossover cable, despite it being a fairly old laptop.
