Curved bed..... July 02, 2014 09:24AM |
Re: Curved bed..... July 02, 2014 09:57AM |
Re: Curved bed..... July 02, 2014 10:00AM |
Re: Curved bed..... July 02, 2014 10:56AM |
Re: Curved bed..... July 02, 2014 12:19PM |
Re: Curved bed..... July 02, 2014 01:07PM |
ChristofSchwiening
Many thanks for all of the replies. I like the three-point support solution Erik. I will have to see how it works with the curved heated bed. I will try putting a washer between the glass and the heater at each clip - that should reduce any bending. I agree, jstck, the glass can't flex that much. So, I need to consider the x-arm. Am I right in thinking, droftarts, that if there is a flex/twist in the x arm then the angle of the extruder head will also change? Surely since the head moves on the rod it can't actually describe a downwards curve - any up or down movement must be associated with a lateral shift. So, if I print a long x-axis straight bar shouldn't it appear curved in the y direction where the head is moving? I will report back later!
Re: Curved bed..... July 03, 2014 08:24AM |
Re: Curved bed..... July 03, 2014 11:39AM |
ChristofSchwiening
..There is a very clear dip down in the glass at the front left corner where the clamp holds the glass......
Re: Curved bed..... July 03, 2014 06:03PM |
Re: Curved bed..... July 03, 2014 06:37PM |
Re: Curved bed..... July 03, 2014 09:42PM |
Re: Curved bed..... July 04, 2014 05:05AM |
Re: Curved bed..... July 04, 2014 05:26AM |
Re: Curved bed..... July 04, 2014 05:38AM |
Re: Curved bed..... July 04, 2014 07:04AM |
Re: Curved bed..... July 04, 2014 10:35AM |
Re: Curved bed..... July 04, 2014 11:02AM |
Re: Curved bed..... July 04, 2014 11:51AM |
droftarts
We had also thought of using the IR probe as a scanner, but there's a patent on that idea... nothing to stop you, though.
Re: Curved bed..... July 04, 2014 06:37PM |
Re: Curved bed..... July 07, 2014 05:52AM |
