Re: Adding Multi extruder support - howto July 29, 2014 05:59AM |
Re: Adding Multi extruder support - howto July 29, 2014 06:51AM |
Re: Adding Multi extruder support - howto July 29, 2014 07:55AM |
Re: Adding Multi extruder support - howto July 29, 2014 09:41AM |
Re: Adding Multi extruder support - howto July 29, 2014 09:53AM |
Re: Adding Multi extruder support - howto July 29, 2014 10:15AM |
Re: Adding Multi extruder support - howto July 29, 2014 10:52AM |
Re: Adding Multi extruder support - howto July 29, 2014 03:21PM |
Re: Adding Multi extruder support - howto July 29, 2014 06:17PM |
Re: Adding Multi extruder support - howto July 31, 2014 03:11PM |
Re: Adding Multi extruder support - howto July 31, 2014 03:33PM |
Re: Adding Multi extruder support - howto July 31, 2014 06:39PM |
Re: Adding Multi extruder support - howto August 01, 2014 02:56AM |
Re: Adding Multi extruder support - howto August 01, 2014 11:13AM |
Re: Adding Multi extruder support - howto August 02, 2014 04:47PM |
Re: Adding Multi extruder support - howto August 03, 2014 11:20AM |
Re: Adding Multi extruder support - howto August 03, 2014 03:27PM |
Re: Adding Multi extruder support - howto August 03, 2014 04:38PM |
Re: Adding Multi extruder support - howto August 03, 2014 04:54PM |
Re: Adding Multi extruder support - howto August 04, 2014 06:31AM |
Re: Adding Multi extruder support - howto August 04, 2014 07:41AM |
Re: Adding Multi extruder support - howto August 04, 2014 04:08PM |
Re: Adding Multi extruder support - howto August 05, 2014 12:25PM |
dc42
I've updated the Duet+X4 and 1/2 nozzle mount designs at [github.com]. The Duet+X4 enclosure now has stronger mounting pillars and access holes for the X4 power terminal screws. The 1-or-2 nozzle mount now has a 'long' option to make it easier to get started with ABS printing, as described by Ludo91 here [forums.reprap.org].
Re: Adding Multi extruder support - howto August 06, 2014 05:12AM |
Re: Adding Multi extruder support - howto August 06, 2014 09:49AM |
Re: Adding Multi extruder support - howto August 06, 2014 11:28AM |
muggi
for the long noozle mount i think we need a lower "sensorpad-diff-led.stl". Can you modify your sensorpad-diff-led.stl for the long noozle mount?
Re: Adding Multi extruder support - howto August 08, 2014 01:46PM |
Re: Adding Multi extruder support - howto August 08, 2014 02:01PM |
Re: Adding Multi extruder support - howto August 08, 2014 04:02PM |
Re: Adding Multi extruder support - howto August 12, 2014 07:03AM |
