The Easy Way to print ABS ![]() July 14, 2014 04:12PM |
Re: The Easy Way to print ABS ![]() July 14, 2014 04:30PM |
Re: The Easy Way to print ABS ![]() July 15, 2014 07:00AM |
Re: The Easy Way to print ABS ![]() July 15, 2014 09:17AM |
Re: The Easy Way to print ABS ![]() July 15, 2014 11:38AM |
Re: The Easy Way to print ABS ![]() July 15, 2014 11:42AM |
Re: The Easy Way to print ABS ![]() July 15, 2014 12:43PM |
Re: The Easy Way to print ABS ![]() July 15, 2014 02:46PM |
zombiepantslol
I always print ABS at a first layer temperature of 120°C and all other layers at a temperature of 90°C on a thin coat of dried glue stick. I usually extrude my ABS at a temperature of 250°C to achieve best line bondage, anything else seems to weaken these parts, but that really depends on the part I print. For smaller parts I can reduce the temperature without problems, because the layer time will be lower anyway.
I get absolutely no warping with iamburny's fan duct, but the difference in my case is a 4-pin PWM-modulated fan. I found that too much filament cooling at the first 30-40 layers inevitably causes ABS parts to warp, so this was a great improvement for me.
Re: The Easy Way to print ABS ![]() July 29, 2014 04:14PM |
Re: The Easy Way to print ABS ![]() July 29, 2014 06:15PM |
Ludo91
I have one doubt tho: I wanna test acetone/abs slur vs hairspray in a "scientific" manner but... I cant make the slur! If I mix acetone and abs the abs become buttery but never dissolves or become antything near somethign that i can apply to the glass.... how so?!
Re: The Easy Way to print ABS ![]() July 30, 2014 10:08AM |
Re: The Easy Way to print ABS ![]() July 30, 2014 10:50AM |
Ludo91
I fixed it but still, I cant understand why slic3r then uses an M190 command to set the first bed temperature and my Ormered just ignores it saying "invalid M code" and for it to work I have to manually change it to M140 in the Gcode. Slic3r then uses correctly M140 to set the bed temperature from second layer on. Any hints?
Re: The Easy Way to print ABS ![]() July 30, 2014 03:47PM |
Re: The Easy Way to print ABS ![]() July 30, 2014 06:21PM |
Re: The Easy Way to print ABS ![]() July 31, 2014 01:05AM |
Re: The Easy Way to print ABS ![]() July 31, 2014 09:50AM |
Re: The Easy Way to print ABS ![]() August 01, 2014 06:43AM |
Re: The Easy Way to print ABS ![]() August 01, 2014 08:16AM |
Re: The Easy Way to print ABS ![]() August 01, 2014 11:49AM |
Re: The Easy Way to print ABS ![]() August 01, 2014 11:54AM |
Re: The Easy Way to print ABS ![]() August 01, 2014 12:46PM |
Re: The Easy Way to print ABS ![]() August 04, 2014 06:13AM |
Re: The Easy Way to print ABS ![]() August 05, 2014 04:23PM |
Re: The Easy Way to print ABS ![]() August 19, 2014 01:40PM |
Re: The Easy Way to print ABS ![]() August 20, 2014 02:24AM |
