Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 08:43AM |
appjaws1
dc42
Thanks for the info, if I had a vote I would vote for the larger processor and more memory in order to remove restrictions on future development and keep the display unit flexible.
I have considered other processors. Unfortunately, the atmega32u4 doesn't have a bigger brother in the same range. The atmega2560 would permit compatibility with the Arduino Mega, but would need a separate FTDI chip and add at least GBP15 to the cost. The atxmega64a4u would be a more economical solution and suitable in principle, but it appears that nobody has yet ported the Arduino core and bootloader to this chip; and I don't have time to do that myself.
That leaves the ATSAM3X8E which would give Arduino Due compatibility. It would need a larger and probably 4 layer PCB, again pushing up cost and development time. I'm trying to keep the cost down to give the device a wider appeal, because the more it costs, the fewer I can sell and the higher the unit assembly cost will be.
Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 09:18AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 09:20AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 09:24AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 09:54AM |
DasBasti
Isn't the ATmega32U4 the chip on the Arduino Yun? So there should be a port of the library.
Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 10:34AM |
dc42
DasBasti
The atmega32u4 chip is the one I am currently using. It has 32K of flash. However, even a simple blink sketch uses 17% of that, so there appears to be a large core overhead. My current test program uses 69% of available memory. One of the problems is that the fonts are quite large. Currently I am using just the 16x16 font, but I find it difficult to read and would prefer 20x20 - which would increase the font memory used by another 87%.
Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 12:33PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 01:04PM |
dmould
Maybe double the pixel size rather than the font size (i.e. map each font pixel to 4 screen pixels)? Granted the letters will be a bit more blocky, but 16 x 16 still gives a very reasonable shape, and even 10 X 10 is perfectly legible (to double up for 20 X 20 onscreen).
ezwul
Are you planning to make a LCD/touch shield for the Arduino Leonardo or a bespoke PCB solution?
Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 02:16PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 06, 2014 06:13PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 07, 2014 07:25AM |
dc42
Another issue that has cropped up is that the utft driver needs the display to be mounted with the connector on the left. I want to keep the PCB small, so the rotary encoder needs to be mounted close to the connector. Having the encoder knob on the left doesn't work well for a right handed person. Therefore I need to modify the driver to allow it to drive an upside down display. This will take a small amount of extra code space. However, it will give left handed users the option of printing an enclosure the other way round, with the encoder on the left. .
dc42
Re: Anyone interested in an LCD control panel for the Ormerod? October 07, 2014 10:42AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 07, 2014 01:47PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 07, 2014 02:00PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 07, 2014 02:11PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 07, 2014 05:27PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 07, 2014 05:35PM |
ezwul
Alternatively, you could make an LCD shield and add an Arduino to it, then you could choose the CPU power depending on your budget.
Due clones are around £15, Leonardo clones are £6 on ebay, Not sure if they are pin compatible, both are 3v, might have to look.
Re: Anyone interested in an LCD control panel for the Ormerod? October 07, 2014 06:06PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 07, 2014 07:52PM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 07, 2014 08:01PM |
dmould
A R-Pi might be cheap, but a display that will accept an HDMI input certainly is not! Unless you can find a small HDMI screen I suspect it will also be too heavy to mount on the Z post.
Dave
Re: Anyone interested in an LCD control panel for the Ormerod? October 08, 2014 01:36AM |
KimBrown
... made me wonder if it might not be easier and more versatile to go the R Pi route ...
Re: Anyone interested in an LCD control panel for the Ormerod? October 08, 2014 04:59AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 08, 2014 06:14AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 08, 2014 07:38AM |
dc42
appjaws1
dc42
have you considered stm32...?
Cheap
Powerful
Ecosystem
EDIT: Dev board or dev board with LCD (Farnell)
regards
Andy
Edited 2 time(s). Last edit at 10/08/2014 07:55AM by kwikius.
Ormerod #318
www.zoomworks.org - Free and Open Source Stuff
Re: Anyone interested in an LCD control panel for the Ormerod? October 08, 2014 07:44AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 08, 2014 08:05AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 08, 2014 08:17AM |
Just to add that if once you learn one ARM mcu architecture then you are well on the way to learning a large number and not limited to 1 manufacturer or ic series. EDIT and TBH Arduino just doesnt scale. All projects seem to end up ditching the standard IDE. You may as well learn standard C or C++ and have done with it! Then if you use GCC porting from one mcu to another or on PC os to another is simple!Quote
dmould
The choice of CPU is predicated to a large extent on what architecture/programming tools you are familiar with and not only the capabilities of the CPU. I'd probably go for a Cypress CY7C67300 - perhaps with external Flash and/or static RAM as a solution for this application, but it would certainly not be worth the learning curve if I wasn't already familiar with it, and I'm sure there are better choices if I was willing to learn a new CPU. The cost of the CPU and support components is in any case probably largely swamped by the PCB, assembly and LCD costs.
Dave
Re: Anyone interested in an LCD control panel for the Ormerod? October 08, 2014 08:40AM |
Re: Anyone interested in an LCD control panel for the Ormerod? October 08, 2014 08:54AM |
kwikius
Just to add that if once you learn one ARM mcu architecture then you are well on the way to learning a large number and not limited to 1 manufacturer or ic series.Quote
dmould
Dave
regards
Andy
Re: Anyone interested in an LCD control panel for the Ormerod? October 08, 2014 09:42AM |
dmould
Have you considered the possibility of using an incremental (up/down) rotary switch (e.g. [uk.rs-online.com]) instead of an encoded switch, which needs only 3 wires (or 4 with push-to-select) and so could be mounted direct on the case with wires to the controller?
