Single- and dual-nozzle differential LED hot end board availability August 29, 2014 12:16PM |
UK EU EU ex VAT Europe non EU Rest of world 1-nozzle board + connectors £49.67 £57.88 £48.23 £48.23 £49.30 1-nozzle board upgrade £43.47 £51.62 £43.01 £43.01 £44.06 2-nozzle board + connectors £60.84 £69.15 £57.63 £57.63 £58.74 2-nozzle board upgrade £57.11 £65.40 £54.50 £54.50 £55.60
Re: Single- and dual-nozzle differential LED hot end board availability August 30, 2014 05:30AM |
Re: Single- and dual-nozzle differential LED hot end board availability September 03, 2014 07:44AM |
Re: Single- and dual-nozzle differential LED hot end board availability September 03, 2014 08:13AM |
Re: Single- and dual-nozzle differential LED hot end board availability September 03, 2014 09:43AM |
appjaws1
Hi David,
When do you expect to want payment for the 2 nozzle upgrade?
Paul
Re: Single- and dual-nozzle differential LED hot end board availability September 05, 2014 05:26PM |
Re: Single- and dual-nozzle differential LED hot end board availability September 08, 2014 11:08AM |
Re: Single- and dual-nozzle differential LED hot end board availability September 10, 2014 01:59PM |
Re: Single- and dual-nozzle differential LED hot end board availability September 12, 2014 09:51AM |
Re: Single- and dual-nozzle differential LED hot end board availability September 12, 2014 12:42PM |
Re: Single- and dual-nozzle differential LED hot end board availability September 14, 2014 09:29AM |
Re: Single- and dual-nozzle differential LED hot end board availability September 23, 2014 01:49PM |
Re: Single- and dual-nozzle differential LED hot end board availability September 29, 2014 05:46PM |
Re: Single- and dual-nozzle differential LED hot end board availability October 01, 2014 12:38PM |
Re: Single- and dual-nozzle differential LED hot end board availability October 01, 2014 01:55PM |
Re: Single- and dual-nozzle differential LED hot end board availability October 01, 2014 03:52PM |
alanbattersby
I am awaiting delivery of one of your dual boards, but will be unable to upgrade to dual nozzles for a while. Can I at least make a start and use the dual board for my single nozzle set-up or does the board expect there to be two nozzles?
Alan
Re: Single- and dual-nozzle differential LED hot end board availability October 13, 2014 05:21AM |
Re: Single- and dual-nozzle differential LED hot end board availability October 13, 2014 08:14AM |
Re: Single- and dual-nozzle differential LED hot end board availability October 13, 2014 11:15AM |
Re: Single- and dual-nozzle differential LED hot end board availability October 13, 2014 12:25PM |
Re: Single- and dual-nozzle differential LED hot end board availability October 13, 2014 12:59PM |
zombiepantslol
Hi Paul, two thoughts:
- If you specify G10 with the S and R parameters in the config file, the firmware will set the active and standby temperatures right after you turn on your machine. So it's no surprise the heaters turn on right away and the fan starts spinning
- IIRC the Duex4 shares its AGND line with the normal GND, which is quite noisy, so you may be better off hacking an extra connector onto the Duet as dc42 did. I believe I saw a few photos on his blog a while ago showing his custom thermistor header glued to the Duet PCB.
Re: Single- and dual-nozzle differential LED hot end board availability October 13, 2014 01:26PM |
Re: Single- and dual-nozzle differential LED hot end board availability October 13, 2014 01:35PM |
Re: Single- and dual-nozzle differential LED hot end board availability October 13, 2014 02:01PM |
dc42
PS - if the voltage drop on the 3.3V rail on the X4 is a constant value, it could be compensated for by connecting a high value resistor between the +5V pin on the X4 expansion connector and the positive thermistor pin (which is the blue wire AFAIR). This would be a less intrusive modification. It wouldn't address the noise issue, but might be enough to correct the head 2 temperature reading and prevent the fan from turning on when the hot end is cold, given the filtering that I already implemented.
Re: Single- and dual-nozzle differential LED hot end board availability October 13, 2014 05:13PM |
appjaws1
What value of resistor would you recommend?
Re: Single- and dual-nozzle differential LED hot end board availability January 12, 2015 08:41AM |
Re: Single- and dual-nozzle differential LED hot end board availability January 26, 2015 03:03PM |
Re: Single- and dual-nozzle differential LED hot end board availability January 27, 2015 03:39AM |
steve0-uk
Hi Dave. If the 4th dual nozzle board is still unallocated, may I request it?
