New firmware 0.89i and web interface 1.03 September 09, 2014 01:07PM |
Merged in more changes from dc42's latest firmware 0.78r (thanks dc42!)
Implemented cold retracts (minimum temperature is 90°C)
G28 and M1 reset homed axes
M0 does no longer disable any drives, M1 still does
Implemented internal G-Code queue to execute codes in-time
When prints are paused, moves stop right after the current move completes
Other minor changes
Firmware binary built with O3 optimization enabled
Updated Arduino libraries to 1.5.6_r2, core patches are on my repo
Rebase from dc42's latest web interface fork (thanks again, dc42!)
Message log can now display line breaks properly
Fan RPM heading is displayed in one line only
Added G32 (automatic bed compensation) to the quick commands
Re: New firmware 0.89i and web interface 1.03 September 15, 2014 02:53AM |
Re: New firmware 0.89i and web interface 1.03 September 15, 2014 05:23AM |
Re: New firmware 0.89i and web interface 1.03 September 15, 2014 06:39AM |
Re: New firmware 0.89i and web interface 1.03 September 15, 2014 08:11AM |
Re: New firmware 0.89i and web interface 1.03 September 15, 2014 11:50AM |
Re: New firmware 0.89i and web interface 1.03 September 15, 2014 03:11PM |
zombiepantslol
Paul, I've just released 0.89j on GitHub. This binary contains most of dc42's changes for 0.78s, including his modifications for G10 offsets, but I haven't merged in his new LCD code yet. If you give it a try, please let me know if it's all working
Re: New firmware 0.89i and web interface 1.03 September 15, 2014 04:52PM |
Re: New firmware 0.89i and web interface 1.03 September 16, 2014 12:56AM |
Re: New firmware 0.89i and web interface 1.03 September 16, 2014 01:17AM |
Re: New firmware 0.89i and web interface 1.03 September 16, 2014 04:37AM |
antlvk
ok it works with your new firmware but having problem with web control
extruder control what ever setting i use also only load by 1mm i cant load 400mm, it will take ages to load my filament, lol
Re: New firmware 0.89i and web interface 1.03 September 16, 2014 05:09AM |
Re: New firmware 0.89i and web interface 1.03 September 16, 2014 07:12AM |
Re: New firmware 0.89i and web interface 1.03 September 16, 2014 07:23AM |
appjaws1
antlvk
I think the Head needs to be active and up to temperature for the extruder control to work.
Re: New firmware 0.89i and web interface 1.03 September 16, 2014 08:23AM |
Re: New firmware 0.89i and web interface 1.03 September 16, 2014 09:24AM |
Re: New firmware 0.89i and web interface 1.03 September 16, 2014 09:39AM |
Re: New firmware 0.89i and web interface 1.03 September 16, 2014 10:25AM |
Re: New firmware 0.89i and web interface 1.03 September 16, 2014 10:40AM |
M569 P0 S1to your config.g file if you don't want to turn around that connector on the Duet.
Re: New firmware 0.89i and web interface 1.03 September 16, 2014 12:21PM |
Re: New firmware 0.89i and web interface 1.03 September 16, 2014 03:17PM |
dc42
Paul, you could try moving the G1 command from the tfree files to the tpre files, then I don't think they should be affected by the nozzle offsets because no tool is selected at that point.
Re: New firmware 0.89i and web interface 1.03 September 20, 2014 07:10AM |
M18 and M84 (disable drives) can disable specified axes and extruders only
More diagnostics code added
Improved file info detection
Other minor changes
