Poor Finished (Solved)
September 12, 2014 10:26AM
For just over a week I've been experiancing a poor finish in parts of my prints.
The rest of the print was first class, but just after a cut out in the side of the print... Yuck!
Here's a picture of what was happening... Sometimes it was so bad I'd have to just throw the print away.
I tweeked settings in Slic3r, but nope.... It was Still there... Not just on one design, but all of them, and it seemed
to be getting worse... I realised it had something to do with the acceleration of the feeder, so started to tweek the settings.
It was just as the first print with the new settings was just starting that the Penny dropped.
I'd been thinking about this allot, and luckily got distracted, and then came back to it, when I thought, 'I wonder if the Hobbed nut's come loose'.
I stripped down the feeder, and sure enough that was the problem.... It wasn't even finger tight any more.
So a dab of super glue, then tightend up with the pliers quickly, and all is well.
Perfect prints again.... Ok I know I may well have to replace the hobbed nut at a later date, as I suspect I won't be able to remove it now.
But the replacement cost is far less than the down time this problem was causing....
Kim
Re: Poor Finished (Solved)
September 12, 2014 11:00AM
Hmmmm seems I spoke to soon. The problem still exists..
Any one got a suggestion please...
September 12, 2014 12:34PM
Which version of slic3r are you using?
September 12, 2014 12:35PM
are your bearings well oiled and the belts tight?
i had a problem alike. are the axis of the parts straigth?
September 12, 2014 01:52PM
Yes,yes & yes
At least sorting out the Hobbed Nut has stopped the Splatter, so that's an improvement.
Edited 1 time(s). Last edit at 09/12/2014 01:54PM by KimBrown.
September 13, 2014 06:49AM
Hi DC 1.1.1 but I don't think it's that as it's something that has appeared over the last week. It's in line with the X axis, so I think I'll remove the x carriage today and see what the bearings like inside, and have a good look at the x axis 12mm rod to see if there's a rough patch or something. The rest of the finish is perfect, so it's annoying that this has appeared. I did have tiny pips on the walls that could be removed with your finger nail, but they've cleared up since I gave the feeder a looking at. I really thought I'd cracked it when I found the hobbed nut loose, but nope, it's still the same.
September 13, 2014 08:09AM
Hi Kim
I ran into something similar, but it followed the infill pattern, yours don't (unless you are using some strange form of vector adding stacked infill pattern) - I do not know what caused it, heat, acceleration speed or global bloody warming, but fixed it with an extra perimeter and reduced speed, 80 to 60mm/sec
have you measured the distance between those blobs? - and if so, do that correlate with anything mechanical ormerod or your local environment?
Erik
September 13, 2014 09:24AM
Hi Erik, yes that does look similar. I think it might be the Extruder Carriage Bearing, I have a spare one some where in that safe place where only the Pope can find it....
Anyway I intend to give it a looking at. I'm wondering if maybe it's a little tight, and then frees up once it's moving. I have some chores to do first then I can sit down and go over the machine with a fine toothed comb. It's the only problem I have with the finish really, so it would be good to nail in down to something. The printer has been busy for the last month or two, and it's had it's moments. But since replacing the extruder cartridge heater, and sorting out the feeder things have really improved a lot.
September 13, 2014 11:05AM
It looks like it's not advancing the filament after retracting, which is leading to weak extrusion just afterwards. We've seen this in some prints in-house too, and we're tracking down the issue - it's possibly a firmware bug related to extruder movement (actually, any motor acceleration when one axis only is moved). We've got a couple of logic analysers (only a couple of £!) to have a good look at exactly what the motor steps are doing. Why it's showing up now, and hasn't previously, is a bit of a mystery. Apart from playing around with the retraction speed (either in config.g or in your Slic3r settings), I don't have any further insight into what's going wrong at the moment, but we're working on it.
Ian
RepRapPro tech support
September 13, 2014 11:09AM
Hi
i also had this issue a view weeks ago.... in my case it was a combination of to "wet" fillament (no sealing against hydroscopic behavior) and a "dirty" not cleaned hobbed insert.
