Is firmware ignoring temperature changes September 19, 2014 11:53AM |
Re: Is firmware ignoring temperature changes September 19, 2014 12:13PM |
Re: Is firmware ignoring temperature changes September 19, 2014 12:17PM |
Re: Is firmware ignoring temperature changes September 19, 2014 12:57PM |
Re: Is firmware ignoring temperature changes September 19, 2014 02:03PM |
Re: Is firmware ignoring temperature changes September 19, 2014 04:25PM |
Re: Is firmware ignoring temperature changes September 20, 2014 01:02AM |
Re: Is firmware ignoring temperature changes September 20, 2014 03:56AM |
Re: Is firmware ignoring temperature changes September 20, 2014 07:17AM |
Re: Is firmware ignoring temperature changes September 20, 2014 09:13AM |
zombiepantslol
I've just released version 0.89l with additional diagnostics code. If your temperature problem persists, please let me know.
dc42's points make sense, can you please post the content of your tpre/tfree/tpost macros from the /sys directory here? Also, what values are displayed in the "Head 1" text box on the web interface at the first three layers? If the target temperatures are displayed properly, you may need to adjust your PID parameters again. If it's a bit off, it's very well possible your extruder temperature varies by a few degrees.
Re: Is firmware ignoring temperature changes September 20, 2014 03:46PM |
appjaws1
If I extract the filament it will ot come all the way out and I have to take the brass union off and then remove the filament. When I look at the filament there is a slight bulge about 10mm from the end...
Re: Is firmware ignoring temperature changes September 21, 2014 11:40AM |
ormerod168
appjaws1
Sounds like you made the same mistake as me and did not bottom out the PTFE tube in the brass bit, the shame...
[attachment 40650 PTFEtube_brassunion.JPG]
Erik
Re: Is firmware ignoring temperature changes September 22, 2014 05:26AM |
appjaws1
That is exactly what my filament looked like, although the bulge is not as big. It is strange because it only just started to happen but I think you are right, because I did have a problem last week when the PTFE tube became unscrewed from the brass union at the extruder motor end and I did not check the other end of the tube for tightness.
Re: Is firmware ignoring temperature changes September 22, 2014 12:00PM |
