slic3r does not start the extruder November 09, 2014 07:31AM |
Re: slic3r does not start the extruder November 09, 2014 08:33AM |
Re: slic3r does not start the extruder November 09, 2014 02:41PM |
Re: slic3r does not start the extruder November 09, 2014 02:46PM |
T1; Select extruder 1
M83; Use relative distances for extrusion
M140 S[first_layer_bed_temperature]; Set bed temperature
G1 X2 Y50 F3000; Go to wait for warm position
M116; Wait for all temperatures
M104 S[first_layer_temperature]; Set extruder temperature
Re: slic3r does not start the extruder November 09, 2014 04:53PM |
Re: slic3r does not start the extruder November 09, 2014 06:11PM |
Re: slic3r does not start the extruder November 10, 2014 04:10AM |
Re: slic3r does not start the extruder November 10, 2014 08:51AM |
Re: slic3r does not start the extruder November 10, 2014 08:54AM |
Re: slic3r does not start the extruder November 10, 2014 10:10AM |
MikeyD
Ian,
When I installed the reprappro slic3r settings from [github.com] I'm fairly sure it didn't add a 'T1' to the start.gcode as I had the same problem as above and had to add it manually.
The printer/Oremerod-0.5.ini file just has start_gcode = G28 Z0\nM83 set.
Could you check please.
Re: slic3r does not start the extruder November 10, 2014 12:43PM |
dmould
I'm not sure about the advice to update to the latest Slic3r. In my experience each version has a different set of bugs, and when I was using Slic3r I had to choose a version that suited a particular print - one version if it had bridges, a different version if it had a large top layer area, yet another for prints where Slic3r decided to omit infilling in some of the walls etc. It seems that the best way may be to slice a model with each version and see which one prints best ...
Dave
