Ormerod2 - Slic3r optimizing November 20, 2014 04:37PM |
Re: Ormerod2 - Slic3r optimizing November 20, 2014 06:18PM |
Re: Ormerod2 - Slic3r optimizing November 21, 2014 04:10AM |
Alex74
Hello,
Today I tried to print a little 'Marvin' with 2.4 x 1.9 x 2.5 cm.
Greetings,
Alex
Re: Ormerod2 - Slic3r optimizing November 21, 2014 05:20AM |
Alex74
,,Today I tried to print a little 'Marvin' with 2.4 x 1.9 x 2.5 cm.
The results are not as good as other Objects. I thing, it is too hot because the Layers are printed to fast and so the PLA is to 'soft or weak' if the next level ist printed? ...
Re: Ormerod2 - Slic3r optimizing November 21, 2014 06:02AM |
Yes it will get too hot nomatter how low you go in layer hight or printing speed (will get worse actually)
Erik
Re: Ormerod2 - Slic3r optimizing November 21, 2014 07:15AM |
Re: Ormerod2 - Slic3r optimizing November 22, 2014 05:31AM |
Ormerod187
Erik
really? I can increase speed and improve the quality?
... firmware?......
I also tried on some print 200% speed but the quality has been lower....
Obviously I can not print 10 Marvin if I have one on order ....my interest is the single piece.
Yes an additional fan helps but with more speed it's not enough with this little Marvin.. (I only tried it once sorry)
Re: Ormerod2 - Slic3r optimizing November 22, 2014 06:37AM |
Re: Ormerod2 - Slic3r optimizing November 24, 2014 05:10AM |
Re: Ormerod2 - Slic3r optimizing November 24, 2014 06:13AM |
Alex74
- If I say to Slic3r that I want layer thickness 0.12mm (instead of 0.24mm), do I have to tell this my Ormerod too in the Webinterface ?
Alex74
- If I choose the "half steps", the resolution of the Steppers will increase. On the GCode I have to change nothing, or
Alex74
- If I want to slow down the last Layers, do I have to do this manually by using the Webinterface (from DC42) ?
Re: Ormerod2 - Slic3r optimizing November 25, 2014 08:54AM |
