Printing ABS December 02, 2014 02:23PM |
Re: Printing ABS December 02, 2014 02:31PM |
Re: Printing ABS December 02, 2014 02:33PM |
Re: Printing ABS December 02, 2014 02:53PM |
Re: Printing ABS December 02, 2014 03:12PM |
Re: Printing ABS December 03, 2014 03:14AM |
Fpex
..The extruder? I thought it is not close to excessive heat
Re: Printing ABS December 03, 2014 12:43PM |
Re: Printing ABS December 03, 2014 01:19PM |
Fpex
That alu axis is more than wished :-)
Re: Printing ABS December 03, 2014 02:58PM |
Re: Printing ABS December 05, 2014 06:00AM |
Re: Printing ABS December 06, 2014 07:56AM |
Re: Printing ABS December 06, 2014 08:42AM |
Re: Printing ABS December 06, 2014 11:30AM |
Re: Printing ABS December 06, 2014 12:35PM |
Re: Printing ABS December 06, 2014 12:38PM |
Re: Printing ABS December 06, 2014 04:49PM |
Re: Printing ABS December 06, 2014 04:58PM |
Re: Printing ABS December 07, 2014 02:42AM |
Re: Printing ABS December 07, 2014 05:00AM |
Re: Printing ABS December 07, 2014 05:59AM |
Jon Steward
When printing with ABS (I've just started) I notice a 'pop' every once in a while from the nozzle as the filament gets extruded...
Re: Printing ABS December 08, 2014 12:36PM |
Re: Printing ABS December 08, 2014 12:56PM |
Jon Steward
Thankfully it's not quite as bad as that green seaweed in your photo!
Looks like I have just the odd air bubble in the filament which pops and leaves a very small gap in the filament trail.
I don't expect perfect filament from cheap ebay sellers.
I did recently get some bad PLA from a different ebay seller to my usual which has random flat spots which get stuck in the extruder and stops the flow, so when doing a long print, has failed annoyingly after a few hours.
Any do's and don't when printing ABS on to glass?
Currently I'm having success with 240 nozzle and 110 bed wiped with vinegar. (although I am seeing some corners lifting a little)
Re: Printing ABS December 08, 2014 01:48PM |
Jon Steward
Re: Printing ABS December 09, 2014 02:14AM |
Jon Steward
Doesn't seem to effect the print.
I assume I have the nozzle temp to high (240)
Re: Printing ABS December 09, 2014 01:08PM |
Re: Printing ABS December 09, 2014 01:15PM |
Re: Printing ABS December 09, 2014 01:42PM |
Jon Steward
I've attached a photo of the ABS extruder printed directly onto glass. I hope I wasn't just lucky
It's important to print a x carriage first in ABS as this fails rapidly. I'm on my second PLA carriage and that's not looking too good.
Though I have now got 2 spare ABS x carriage and an ABS extruder now.
Re: Printing ABS December 09, 2014 02:01PM |
Mick747
..I have the Ormerod V2 and wondered if this is something i can do and also what benefit does it give?
Many Thanks.
Mick.
Re: Printing ABS December 09, 2014 02:05PM |
ormerod168
Mick747
Many Thanks.
Mick.
Or you could ask what benefit did the aluminium plate give - I saw non whatsoever and removed it long ago, benefits, lighter bed, nothing to disturb the flatness of the glass, less risk of shorting and roasting the duet
..I put it to good use for a while, moved it down on top of the MDF bed as support for the always moving and sagging corners (ormerod1) - now its integrated in a new Y carriage assembly
[attachment 44929 alubed.JPG]
Erik
Re: Printing ABS December 10, 2014 02:18AM |
ormerod168
Did you print the x-carriage on glass too? - and with no brim?, its rather high print that might slip and tip over
Erik
