Re: Printing ABS December 10, 2014 04:47AM |
Re: Printing ABS December 15, 2014 07:08AM |
Jon Steward
..I must be really lucky as I've now managed to print off 3 ABS x carriages directly to glass...
The Adventure of Sherlock Holmes' Smarter Brother
Orville: Are you Mister S., for Sigerson, Holmes?
Sigerson Holmes: Perhaps.
Orville: Do you have a brother whose first name is Sherlock?
Sigerson Holmes: I do not.
Orville: You do have a brother?
Sigerson Holmes: I do.
Orville: Might I inquire as to his first name?
Sigerson Holmes: "Sheer luck."
Re: Printing ABS December 15, 2014 12:56PM |
Re: Printing ABS December 16, 2014 02:31PM |
Jon Steward
Erik. You do need to get out more!
I'm really motoring now with ABS on glass.
Thought I might try a 2mm brim on the latest ABS on glass print.
Re: Printing ABS December 16, 2014 02:42PM |
Re: Printing ABS December 20, 2014 03:03AM |
Re: Printing ABS December 20, 2014 05:21AM |
Re: Printing ABS December 21, 2014 09:48AM |
Re: Printing ABS December 21, 2014 10:31AM |
Re: Printing ABS December 21, 2014 11:10AM |
Re: Printing ABS December 21, 2014 01:25PM |
zombiepantslol
Hmm, hairspray has never worked for me. I've been using this alu plate instead..
..acetone will actually dissolve its coating. I didn't know that before either, but someone (Erik I believe?) tried it and it didn't go out too well..
http://3deksperten.dk/buildtak-3d-print-plade-vaelg-storrelse.html
BuildTak is a thin, durable plastic sheet that adheres to the print bed of FDM (fused deposition modeling) 3D printers to provide an ideal surface for 3D printing. It replaces the need for blue masking tape and/or polyimide films such as Kapton. Composed of high quality, heat-resistant raw materials, BuildTak provides a stable build platform for 3D printed objects to adhere to while allowing for a clean, easy removal of completed builds.
Re: Printing ABS December 21, 2014 03:15PM |
Fpex
Tell me more about the nylon. I also have but not used the alu plate because I found the carbon works great for pla and abs, even with lower temps. And the air spray is very effective above 50C.
But now. I Get worried for nylon ruining my plates.
Re: Printing ABS December 21, 2014 05:15PM |
Re: Printing ABS December 21, 2014 05:20PM |
Fpex
does the ormerod do above 100 as bed temp? I thought it was still 100 and really slow!!
Re: Printing ABS December 21, 2014 06:05PM |
Re: Printing ABS December 21, 2014 06:19PM |
Re: Printing ABS December 22, 2014 03:20AM |
Re: Printing ABS December 22, 2014 03:34AM |
Re: Printing ABS December 22, 2014 05:34AM |
Jon Steward
Is 14VOK?. I read in the instructions the 13.5V was the highest. Don't want to damage anything.
Is that 14V measured at the PSU with no load?
Re: Printing ABS December 23, 2014 06:22AM |
