Trouble with infills - gaps and other artefacts - slic3r settings December 15, 2014 06:04PM |
; generated by Slic3r 0.9.10b on 2014-12-13 at 16:02:45 ; layer_height = 0.24 ; perimeters = 2 ; top_solid_layers = 3 ; bottom_solid_layers = 2 ; fill_density = 0.3 ; perimeter_speed = 45 ; infill_speed = 45 ; travel_speed = 250 ; nozzle_diameter = 0.5 ; filament_diameter = 1.75 ; extrusion_multiplier = 1 ; perimeters extrusion width = 0.85mm ; infill extrusion width = 0.87mm ; solid infill extrusion width = 0.85mm ; top infill extrusion width = 0.85mm ; first layer extrusion width = 0.80mm
Re: Trouble with infills - gaps and other artefacts - slic3r settings December 16, 2014 02:56AM |
dannystaple
Re: Trouble with infills - gaps and other artefacts - slic3r settings December 16, 2014 08:49AM |
ormerod168
Slic3r will normally set the extrusion multiplier to nozzle size unless you force it in expert setting, you could try again with those settings at default
Re: Trouble with infills - gaps and other artefacts - slic3r settings December 16, 2014 09:07AM |
Re: Trouble with infills - gaps and other artefacts - slic3r settings December 16, 2014 02:56PM |
ormerod168
Edit: "travel_speed = 250" - wow!, Is that the new normal??, sound a bit excessive to me, my setting is 80
Re: Trouble with infills - gaps and other artefacts - slic3r settings December 16, 2014 05:42PM |
Re: Trouble with infills - gaps and other artefacts - slic3r settings December 17, 2014 07:12AM |
But are you sending an M203 in command to allow speeds that high? If not the moves will be limited to the default max speed and the 200mm/s set speed is being ignored ...Quote
dannystaple
I've certainly had no missed steps - so that doesn't appear to be a problem - and these are based upon loading the config files from the ormerod github repo.
Re: Trouble with infills - gaps and other artefacts - slic3r settings December 17, 2014 08:08AM |
Re: Trouble with infills - gaps and other artefacts - slic3r settings December 17, 2014 08:12AM |
Re: Trouble with infills - gaps and other artefacts - slic3r settings December 18, 2014 01:30PM |
zombiepantslol
ormerod168
That sounds quite slow, don't you have any problems with ooze?
