Web control of extruder is dead
January 06, 2015 01:22AM
When turn on and try tu retract or forward in any speed or length it won't work. please help
Using Web 1.08 and 0.96i-zpl firmware
Here is my config
; Configuration file for RepRap Ormerod
; RepRapPro Ltd
M111 S0 ; Debug off
M550 PAnthony's Ormerod 3D Printer ; Machine name (can be anything you like)
M551 Preprap ; Machine password (currently not used)
M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address
M552 P192.168.31.144 ; IP address
M553 P255.255.255.0 ; Netmask
M554 P192.168.31.1 ; Gateway
M555 P2 ; Set output to look like Marlin
G21 ; Work in millimetres
G90 ; Send absolute corrdinates...
M83 ; ...but relative extruder moves
M906 X800 Y1000 Z800 E800 ; Set motor currents (mA)
M563 P1 D0 H1 ; Define tool 1
G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures
M92 E433 ; Set extruder steps per mm
M558 P1 ; Use an unmodulated Z probe
G31 Z1.4 P656 ; Set the probe height and threshold
M557 P0 X65 Y10 ; Four...
M557 P1 X65 Y160 ; ...probe points...
M557 P2 X200 Y160 ; ...for bed...
M557 P3 X200 Y10 ; ...levelling
M556 S78 X0 Y0 Z0 ; Put your axis compensation here
M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2)
M203 X15000 Y15000 Z60 E3600 ; Maximum speeds (mm/min)
M566 X800 Y800 Z30 E20 ; Minimum speeds mm/minute
Re: Web control of extruder is dead
January 06, 2015 03:51AM
Does Head 1 show up as Active in the web interface? If not, click on the Head 1 text to activate it. Or put a T1 command at the end of config.g.
January 06, 2015 04:14AM
It shows up as Active
January 06, 2015 04:17AM
; RepRapPro Ltd
M111 S0 ; Debug off
T1
January 06, 2015 04:18AM
And all motor are powered except extruder
January 06, 2015 04:36AM
I just remembered: zpl's firmware does not allow cold extrudes by default (mine does). Try sending M302 P1.
January 06, 2015 04:46AM
It works, Thank you very very much
January 06, 2015 05:16AM
New problem, after finish printing. The extruder restract the whole loaded filament out automatically
January 06, 2015 05:17AM
G0 F9000 X99.922 Y96.704
G1 F2100 E677.11110
G0 F9000 X99.922 Y96.704 Z14.000
; Default end code
;G1 X0 Y0 Z130 ; Get extruder out of way. Uncomment to use!
G1 X2 Y190; park the machine
;M1
;M107 ; Turn off fan
; Disable all extruder
;G91 ; Relative positioning
T1
G1 E-1 ; Reduce filament pressure
;M104 T0 S0
;G90 ; Absolute positioning
;G92 E0 ; Reset extruder position
;M140 S0 ; Disable heated bed
;M84 ; Turn steppers off
January 06, 2015 07:51AM
Replace
T1
with
M83 ; Use relative E distances
G1 E-4 ; Retract 4mm of filament
and it should work.
January 06, 2015 08:58AM
zombiepantslol
Replace
T1
with
and it should work.
I expect it will, but I am puzzled. Anthony's config file puts the extruder in relative mode, so unless that was changed in the slicer's start code (which he has not shown), I do not see why it should be necessary to issue the relative command again.
Dave
January 06, 2015 01:37PM
dmould
Heh yes, but have a look at his last extruding move:
G1 F2100 E677.11110
I doubt he wants to extrude 677mm of filament at once, so my guess is that he enables absolute extruder positions somewhere in his start code winking smiley
January 07, 2015 06:55AM
zombiepantslol
dmould
G1 F2100 E677.11110
I didn't spot that. If it has been explicitly changed to absolute mode, the end code is requesting that all the filament used plus a bit more be rewound, and is working perfectly correctly. So no changes needed ;-)
Dave
Edited 1 time(s). Last edit at 01/07/2015 06:56AM by dmould.
January 12, 2015 02:20AM
I'm confused. Should I run Absolute position or Relative Position?
January 12, 2015 03:12AM
Relative extruder position is preferred for the Duet firmware.
January 12, 2015 09:08AM
antlvk
With all the latest firmware it won't make any difference to the print, though relative moves for the extruder are more logical to me so are what I use. Cura however can only output absolute extruder moves, so if you want to use Cura without any plugins to convert the output you will need to switch the Duet to absolute mode. Whatever you choose however, you must be consistent. A negative move in relative mode will retract just the amount of the move, but in absolute mode it will retract the total length that has been extracted since the last "G92 E0" command plus the negative amount more. Probably best would be to explicitly change the extruder to relative mode before doing the retraction in your custom end code.
Dave
January 12, 2015 10:15PM
I'm using Cura engine in Repetier. Maybe that is the problem?
