Re: New firmware 1.00-dc42 January 28, 2015 05:47AM |
Re: New firmware 1.00-dc42 January 28, 2015 06:13AM |
Mercnik
Ok.
But i have 1.00a firmware.
Re: New firmware 1.00-dc42 January 28, 2015 06:51AM |
Re: Error: Attempting to extrude with no tool selected January 28, 2015 07:52AM |
dc42
Hmm - strange! I've just checked the PanelDue source code, and the only time it sends T0 is if you touch either the Head 0 or Head 1 text when that head is already active.
Can you use either the web interface or the PanelDue to check whether tool 1 is active when you start the print, and when it goes inactive? The web interface displays the head status in small text under the Head 1 or Head 2 text. PanelDue does it by setting the background colour of the active head current temperature to red.
Also, if you are still running version 1.00 PanelDue firmware, please upgrade to version 1.01 so that we are both using the same version. The firmware version number is displayed on the Setup page.
Re: Error: Attempting to extrude with no tool selected January 28, 2015 09:17AM |
dc42
Re: Error: Attempting to extrude with no tool selected January 28, 2015 09:52AM |
dmould
dc42
If I read pantau's posts correctly, he has sometimes had the hotend switch off mid-print. If so it sounds as if the PanelDue has had a touchpanel input deselecting the head, maybe an accidental touch, an erroneous touchpanel output (due to vibration?) or electrical noise on the touchpanel signal lines. There is also an outside possibility that the touchpanel driver has a bug that gives ghost outputs under some conditions (typically when interrupts occur or are disabled at a critical time). I am not familiar with your panel interface, but if it is possible to switch to a screen where there are no buttons present that would deselect the tool, pantau could try switching to that screen after the print is underway.
Given the possibility of accidentally touching the screen (depending where it is mounted), maybe consider a way of minimising the risk of an accidental touch ruining a print that is underway, such as "lock" and "unlock" functions.
I once lost several hours work when a cat I was looking after for a friend jumped onto my keyboard and managed to hit just the right key combination. My fault for not saving the work often enough, but I was not pleased with the cat!
Dave
Re: New firmware 1.00-dc42 January 28, 2015 09:59AM |
Re: New firmware 1.00-dc42 January 28, 2015 10:08AM |
Re: Error: Attempting to extrude with no tool selected January 28, 2015 10:19AM |
Re: New firmware 1.00-dc42 January 31, 2015 08:04AM |
Re: New firmware 1.00-dc42 January 31, 2015 09:25AM |
* Added M575 command to set baud rate and whether or not commands are required to have checksums. See [reprap.org].
* Default aux baud rate is now 57600.
* Added support for a Z probe switch connected to the E0 endstop pins.
* Added "geometry" variable in M105 S3 status response.
Re: New firmware 1.00-dc42 February 04, 2015 05:44AM |
Re: New firmware 1.00-dc42 February 05, 2015 06:37AM |
Re: New firmware 1.00-dc42 February 05, 2015 07:32AM |
nistrum
Hey DC.
i know this is probably going to seem like an obvious question.. but what is the best way to update the firmware?
i have not done it for ages so was thinking i would try the RRP website way. but i cant for the life of me find the bossac.exe im guessing the newest arduino versions dont still have it? sould i just pull the SD card and overwrite the files?
Re: New firmware 1.00-dc42 February 05, 2015 07:42AM |
Re: New firmware 1.00-dc42 February 05, 2015 10:34PM |
Re: New firmware 1.00-dc42 February 06, 2015 05:16AM |
Re: New firmware 1.00-dc42 February 06, 2015 05:56AM |
Re: New firmware 1.00-dc42 February 06, 2015 07:37AM |
Re: New firmware 1.00-dc42 February 06, 2015 11:46AM |
Re: New firmware 1.00-dc42 February 08, 2015 06:12PM |
Re: New firmware 1.00-dc42 February 09, 2015 10:26AM |
; Configuration file for RepRap Ormerod ; RepRapPro Ltd M111 S0 ; Debug off M550 PRaffyBuffy ; Machine name (can be anything you like) M551 Preprap ; Machine password (currently not used) M540 P0xBE:0xEF:0xDE:0xAD:0xFE:0xED ; MAC Address ;*** Adjust the IP address and gateway in the following 2 lines to suit your network M552 P192.168.1.14 ; IP address M554 P192.168.1.1 ; Gateway M553 P255.255.255.0 ; Netmask M555 P2 ; Set output to look like Marlin G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves M906 X800 Y1000 Z800 E1000 ; Set motor currents (mA) M563 P1 D0 H1 ; Define tool 1 G10 P1 S0 R0 ; Set tool 1 operating and standby temperatures M92 Z2133 ; Set Z steps per mm M92 E420 ; Set extruder steps per mm (single nozzle) ;*** If you have a dual-nozzle build, remove ot comment out the previous line, and un-comment the following 3 lines ;M563 P2 D1 H2 ; Define tool 2 ;G10 P2 S0 R0 ; Set tool 2 operating and standby temperatures ;M92 E420:420 ; Set extruder steps/mm (dual nozzle) ;*** If you have a modulated IR probe without on-board microcontroller, change P1 to P2 in the following M558 P1 ; Use an unmodulated Z probe or an intelligent Z probe G31 Z0.3 P500 ; Set the probe height and threshold (put your own values here) ;*** If you have a Duet 0.7 board, change R1000 to R4700 to the following M305 commands M305 P0 R1000 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction M305 P1 R1000 H26 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction M305 P2 R1000 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction ;*** Adjust the XY coordinates in the following M557 commands to suit your build and the position of the IR sensor M557 P0 X60 Y60 ; Four... M557 P1 X60 Y165 ; ...probe points... M557 P2 X165 Y165 ; ...for bed... M557 P3 X165 Y60 ; ...levelling M557 P4 X141 Y82.5 ; 5th probe point for levelling (un-comment this if you are using a dc42 differential IR probe) ;*** if you are using axis compensation, put the figures in the following command M556 S78 X0 Y0 Z0 ; Axis compensation here M201 X800 Y800 Z15 E1000 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min) M566 X600 Y600 Z30 E20 ; Minimum speeds mm/minute M208 X214 Y210 ; set axis maxima (adjust to suit your machine) M208 X-8 S1 ; set axis minimum (adjust to make X=0 the edge of the bed) M574 X0 Y2 Z0 S1 ; set endstop configuration (Y endstop only, at high end, active high)
Re: New firmware 1.00-dc42 February 09, 2015 12:38PM |
Re: New firmware 1.00-dc42 February 09, 2015 01:01PM |
Re: New firmware 1.00-dc42 February 09, 2015 04:42PM |
dc42
Is it an Ormerod 1 or 2, and are you using my homing files or RRP's? You can use either, but on the O1 mine behave a little differently from RRP's:
- RRP's homing files includes a G92 command after the homing move, because homing won't work without it using their firmware.
- Mine don't have the G28 command. Instead, the firmware sets the Y position to the value given in the M208 command (which you have set to 210) when it senses the high stop. On my machine, the nozzle is right at one end of the bed when the endstop is triggered, so Y=210 this is about right. But if you have your Z axis mounted in a different position on the Y extrusion so that the nozzle can't quite reach the left hand end of the bed, then you may need to reduce that 210 figure.
Re: New firmware 1.00-dc42 February 12, 2015 02:19PM |
Re: New firmware 1.00-dc42 February 12, 2015 04:28PM |
Re: New firmware 1.00-dc42 February 12, 2015 06:34PM |
Re: New firmware 1.00-dc42 February 13, 2015 10:12AM |
