Enhancement - Adjusting twisted Y bars on Ormerod 1 February 13, 2015 12:43PM |
Re: Enhancement - Adjusting twisted Y bars on Ormerod 1 February 13, 2015 02:13PM |
Re: Enhancement - Adjusting twisted Y bars on Ormerod 1 February 17, 2015 03:24AM |
Re: Enhancement - Adjusting twisted Y bars on Ormerod 1 August 07, 2017 03:14AM |
Re: Enhancement - Adjusting twisted Y bars on Ormerod 1 August 07, 2017 04:18AM |
appjaws1
I have found the setting up of the bed to ensure levelness has been a real pain, so inspired by fotomas's modification for the Y Idler Bracket on the ormerod 2 and johneato's Y belt tensioning device for the ormerod 1, I have modified the Y idler bracket so that the acrylic Y axis end plate can be raised or lowered by an adjustment wheel. I have also removed the countersink holes that join the Y Idle bracket to the Y axis end plate and replaced them with straight holes.
[attachment 49221 appjaws-Y-Idler-Modified-v1-right.png] the stl for the Y Idle without Y belt adjustment is [www.dropbox.com]
the stl for the Y Idle with Y belt adjustment is [www.dropbox.com]
[attachment 49223 appjaws-Y-Idler-Modified-v2-left.png] [attachment 49224 appjaws-Y-Idler-Modified-v2-right.png]
the stl for the adjustment ring is [www.dropbox.com] the stl for the Y belt tensioner is [www.dropbox.com]
[attachment 49222 appjaws_Y_Idler_adjustment_ring.png] [attachment 49225 appjaws_Y_Idler_tensioner.png]
You will need 1 x 30mm hexagon headed M3 bolt, 2 x 15mm cap head M3 bolts and 2 M3 nuts
Attach the Y idler bracket to the aluminium extrusion and tighten the 2 M5 countersink bolts and the M4 bolt and tee nut.
Using 2 15mm cap head M3 bolts, loosely attach the the Y axis end plate to the Y idler bracket, so that the acrylic end plate can move but is not sloppy.
Attach the Y belt as per the reprap instructions
Place the adjusting wheel in the adjusting slot and fix with the 30mm M3 bolt and M3 nut.
Check the bed for level.
If the P3 position is low then turn the adjusting wheel anti-clockwise just past where resistance is felt and if P2 is high turn the wheel clockwise just past where resistance is felt.
Re-check the bed for level and repeat in stages until you have a level bed at all 4 corners. You may well need to adjust the height of the bed at the centre front point.
Finally tighten the 2 fixing bolts and re-check the levels.
[attachment 49226 Y_Idler_V2-fitted.jpg]
Re: Enhancement - Adjusting twisted Y bars on Ormerod 1 August 11, 2017 12:21PM |
Re: Enhancement - Adjusting twisted Y bars on Ormerod 1 August 12, 2017 10:22AM |
Re: Enhancement - Adjusting twisted Y bars on Ormerod 1 August 12, 2017 11:37AM |
sinnedwrong
so the real issue is the availability or y-axis-end-plate.DXF called on line 99
Thoughts?
Dennis
Re: Enhancement - Adjusting twisted Y bars on Ormerod 1 August 12, 2017 01:38PM |
Re: Enhancement - Adjusting twisted Y bars on Ormerod 1 August 12, 2017 03:25PM |
sinnedwrong
I would imagine test_square_pyramid is in the include file on line 4 (In my file dated 9/5/2014 21:51 at 6kb the final lines are :
// Tests:
test_square_pyramid(){square_pyramid(10, 20, 30);}
i.e the "module" keyword is missing) however I can't see this module called anywhere so I don't think it matters
Re: Enhancement - Adjusting twisted Y bars on Ormerod 1 August 15, 2017 10:32AM |
Re: Enhancement - Adjusting twisted Y bars on Ormerod 1 August 16, 2017 09:58AM |
