Tool Number Changed March 26, 2015 09:19AM |
Re: Tool Number Changed March 26, 2015 09:26AM |
Re: Tool Number Changed March 26, 2015 09:34AM |
Re: Tool Number Changed March 26, 2015 10:01AM |
Re: Tool Number Changed March 26, 2015 10:08AM |
Don Recardo
Thank you both for the answers
I will upgrade soon
I take it there is nothing I need to change in slic3r
Re: Tool Number Changed March 26, 2015 10:45AM |
Don Recardo
I will upgrade soon
Re: Tool Number Changed March 26, 2015 10:52AM |
Re: Tool Number Changed March 26, 2015 10:56AM |
dc42
So you don't need to change your start gcode. But is a good idea to put a T command in your start gcode, to select the hot end at the start. If you don't do this, you may find that when a print has finished, if you want to start another one then you have to send that T0 or T1 command first for the print to succeed. This is because the M0 or M1 command in the end gcode of the first print has deselected the tool.
Re: Tool Number Changed March 26, 2015 01:28PM |
Don Recardo
so do I just add T0 to my start code so it becomes
T0
G28 Z0
M83
Re: Tool Number Changed March 28, 2015 11:20AM |
M563 P0 D0 H1 M563 P1 D0 H1
Re: Tool Number Changed March 28, 2015 04:26PM |
jstck
I'm on duet/panel firmware 1.04b / 1.09. I've changed everything "new"and I have gcode files using both tool 0 and 1, and I was able to print both kinds by defining both T0 and T1 (being the same tool, on my single-extruder machine):
It seems to work, only downside I can see is that the user interface thinks there are two separate tools. Are there any real adverse effects to having "two tools" like this?
Re: Tool Number Changed March 28, 2015 06:26PM |
