New firmware 1.04c-dc42 April 02, 2015 03:58PM |
Implemented rr_config web request for version 1.05 of DuetWebControl
Implemented 7-factor auto calibration for delta printers
Fix bug with fileinfo calls corrupting memory
M563 can now be used to delete tools (thanks rrp/zpl)
When activating or changing tools, the tool change macro files are only run if the printer has been fully homed. This is so that on a 2-nozzle machine, you can put a T0 command at the end of config.g without the head trying to move beyond the end of the axes.
Re: New firmware 1.04c-dc42 April 02, 2015 04:39PM |
Re: New firmware 1.04c-dc42 April 02, 2015 07:01PM |
Re: New firmware 1.04c-dc42 April 03, 2015 03:32AM |
dc42
Doug, I'm about to start a thread in the Delta section of the forum about this facility.
Re: New firmware 1.04c-dc42 April 04, 2015 07:46AM |
Re: New firmware 1.04c-dc42 April 04, 2015 09:20AM |
Re: New firmware 1.04c-dc42 April 04, 2015 01:52PM |
Re: New firmware 1.04c-dc42 April 04, 2015 02:07PM |
Darathy
Hey dc i have just upgraded to your firmware 1.04c and i cant seem to get the speeds correct for g1 commands correct (example G1 X60 Y4) ,it moves really slow like 1mm/s or slower. also when i home my Z axis if it is on other side of the bed or at start of printing after bed temp reaches 65. even printing seems a lot slower then when i had repraps firmware 0.78c
Re: New firmware 1.04c-dc42 April 04, 2015 02:49PM |
Re: New firmware 1.04c-dc42 April 04, 2015 04:39PM |
Re: New firmware 1.04c-dc42 April 06, 2015 10:03AM |
Re: New firmware 1.04c-dc42 April 06, 2015 02:08PM |
Re: New firmware 1.04c-dc42 April 07, 2015 11:15AM |
Re: New firmware 1.04c-dc42 April 07, 2015 05:30PM |
Re: New firmware 1.04c-dc42 April 08, 2015 07:49AM |
gdwinslow
Hi All, Installed the 1.04c Firmware and the 1.05 web interface. In all it appears to be working. I do have a Strange problem though and am not sure where to look. The G32 command goes to my 4 points and Pushes the z Height down till it reaches the Threshold i set in my 'G31 P500 Z1.55' command, but it dos not slow down and go till the LED Is lit on the Sensor board. I am running one of DC42 Sensor boards for Single Ext-ruder. Any suggestions?
Re: New firmware 1.04c-dc42 April 08, 2015 08:00AM |
dmould
Have you set the correct sensor type in your config.g file? There are 3 possible types AFAIK, the original unmodulated sensor, the modulated sensor and DC42's differential sensor. I don't think the first two have a two-stage homing speed, but just look for a threshold value. I am not at my printer and cannot recall the correct command to use to select the sensor type.
Re: New firmware 1.04c-dc42 April 08, 2015 09:44AM |
zombiepantslol
dmould
AFAIK both dc42's and my firmware fork slow down the Z movement as it approaches the target Z value (IIRC when the firmware measures ~90% of the threshold value). The code you were looking for is M558, which accepts at least three different probe types:
- P0: No probe type, i.e. an endstop switch
- P1: Unmodulated IR probe such as dc42's excellent IR sensor board
- P2: Modulated IR sensor such as the default Ormerod probe
- P3 is only supported by dc42's and my firmware fork and can be specified if dc42's ultrasonic board is used
Re: New firmware 1.04c-dc42 April 08, 2015 03:44PM |
Re: New firmware 1.04c-dc42 April 09, 2015 04:34PM |
Re: New firmware 1.04c-dc42 April 09, 2015 04:51PM |
Europa
Hello zpl,
May I ask you about your excellent web interface?
I did try it with DC42s 1.04c firmware and your web interface version 1.05.
I found it to be an excellent interface with lots of features but the one problem I experienced was uploading files to the SD card, it just would not work, in the end I reluctantly returned to Ianburnys web interface.
Will you be bringing out an update to fix the problem?
Many thanks,
Brian
Re: New firmware 1.04c-dc42 April 09, 2015 05:27PM |
Re: New firmware 1.04c-dc42 April 09, 2015 11:44PM |
Re: New firmware 1.04c-dc42 April 10, 2015 03:51AM |
Re: New firmware 1.04c-dc42 April 10, 2015 07:07AM |
Re: New firmware 1.04c-dc42 April 10, 2015 09:12AM |
zombiepantslol
dc42, did this problem occur when you tried to upload the same file(s) at least twice? If so, I'll look into it. I had a similar issue a while ago, but I actually thought this would be fixed.. Are you still using Chrome?
Re: New firmware 1.04c-dc42 April 10, 2015 09:35AM |
$("#input_file_upload").val("");
$("#input_file_upload").val()
Re: New firmware 1.04c-dc42 April 10, 2015 12:15PM |
Re: New firmware 1.04c-dc42 April 11, 2015 04:57AM |
Re: New firmware 1.04c-dc42 April 11, 2015 03:23PM |
