Re: .3mm quickset nozzle woes! July 01, 2015 08:16AM |
Re: .3mm quickset nozzle woes! July 01, 2015 10:00AM |
Re: .3mm quickset nozzle woes! July 01, 2015 10:38AM |
Re: .3mm quickset nozzle woes! July 01, 2015 02:26PM |
appjaws1
I have the same problem with 0.5mm quick set nozzles.
Just changed the fan for a thinner one that will reduce the air flow across the nozzle.
I thought changing to the quick set nozzles would be a real advantage but I have been having allsort of problems i.e. with the ormaxis print, during the tall pillar, the print fails with the nozzle not extruding at all. So I thought that it could have been caused by retraction, hot end too hot or speed too fast. I tried to adjust all of these but still had the problem. Lets hope that the reduction in cooling might solve the problem.
Re: .3mm quickset nozzle woes! July 01, 2015 05:23PM |
Re: .3mm quickset nozzle woes! July 02, 2015 02:44AM |
Re: .3mm quickset nozzle woes! July 02, 2015 03:57AM |
Re: .3mm quickset nozzle woes! July 02, 2015 08:05AM |
dmould
The G-code produced for a 0.5mm nozzle should work for a 0.3mm nozzle - it certainly would not cause blockages.
The only relevant difference between printing the arms and the Z column I can think of is the average extrusion speed and possibly the frequency of retractions. A slower average rate of extrusion would allow heat to travel further up the filament.
Dave
Re: .3mm quickset nozzle woes! July 02, 2015 11:38AM |
Re: .3mm quickset nozzle woes! July 03, 2015 06:00AM |
Re: .3mm quickset nozzle woes! July 03, 2015 06:13AM |
; external perimeters extrusion width = 0.50mm ; perimeters extrusion width = 0.50mm ; infill extrusion width = 0.50mm ; solid infill extrusion width = 0.50mm ; top infill extrusion width = 0.50mm
