Ormerod 1 + Duet Shield April 18, 2015 06:46AM |
Re: Ormerod 1 + Duet Shield April 18, 2015 07:58AM |
M569 P0 S1 ; Reverse the X motor M563 P0 D0 H1 ; Define tool 1 G10 P0 S0 R0 ; Set tool 1 operating and standby temperatures M563 P1 D1 H2 ; Define tool 2 (un-comment this for dual nozzle machines) G10 P1 X19 S0 R0 ; Set tool 2 operating and standby temperatures (un-comment this for dual nozzle machines) M92 E447:447 ; Set extruder steps per mm M558 P1 ; Use an unmodulated Z probe G31 Z2.1 P650 ; Set the probe height and threshold M305 P0 R1000 H0 L0 ; Put your own H and/or L values here to set the bed thermistor ADC correction M305 P1 R1000 H0 L0 ; Put your own H and/or L values here to set the first nozzle thermistor ADC correction M305 P2 R1000 H0 L0 ; Put your own H and/or L values here to set the second nozzle thermistor ADC correction
Re: Ormerod 1 + Duet Shield April 18, 2015 08:33AM |
Re: Ormerod 1 + Duet Shield April 18, 2015 09:59AM |
Re: Ormerod 1 + Duet Shield April 18, 2015 11:28AM |
appjaws1
What are the Pros and Cons of the duet shield v DuetX2
Re: Ormerod 1 + Duet Shield April 18, 2015 11:41AM |
Re: Ormerod 1 + Duet Shield April 18, 2015 01:40PM |
Re: Ormerod 1 + Duet Shield April 18, 2015 02:33PM |
Re: Ormerod 1 + Duet Shield April 18, 2015 03:21PM |
Re: Ormerod 1 + Duet Shield April 18, 2015 05:28PM |
Re: Ormerod 1 + Duet Shield April 19, 2015 07:12AM |
dc42
Have you used an M305 command in config.g to say that heater 2 thermistor has a 4K7 series resistor instead of 1K? If not, the thermistor will read around 60C at room temperature.
Re: Ormerod 1 + Duet Shield April 19, 2015 09:33AM |
Re: Ormerod 1 + Duet Shield April 19, 2015 10:50AM |
Re: Ormerod 1 + Duet Shield April 19, 2015 11:08AM |
Re: Ormerod 1 + Duet Shield April 19, 2015 01:12PM |
Re: Ormerod 1 + Duet Shield April 25, 2015 07:10AM |
Re: Ormerod 1 + Duet Shield July 16, 2015 09:34AM |
Re: Ormerod 1 + Duet Shield July 16, 2015 01:43PM |
ThorsenRune
Ababuy: You have the yellow and red inverted with respect to the instructions. Did you also invert them for the second fan connection?
and where the second fan is supposed to be mounted?
Anybody ?
Re: Ormerod 1 + Duet Shield July 22, 2015 04:06AM |
Re: Ormerod 1 + Duet Shield July 22, 2015 04:14AM |
Re: Ormerod 1 + Duet Shield July 22, 2015 04:20AM |
Re: Ormerod 1 + Duet Shield December 17, 2015 12:01PM |
Re: Ormerod 1 + Duet Shield December 17, 2015 12:57PM |
M563 P127...
Re: Ormerod 1 + Duet Shield December 18, 2015 04:35AM |
