Commissioning an Ormerod 2 May 07, 2015 11:13AM |
Re: Commissioning an Ormerod 2 May 07, 2015 11:24AM |
Re: Commissioning an Ormerod 2 May 07, 2015 01:57PM |
I thought they preloaded the cards with firmware.Quote
zombiepantslol
It sounds like you haven't flashed the Duet yet. Also, when you connect the Duet via Ethernet to your computer, you must assign a static IP address to your LAN adapter first.
Re: Commissioning an Ormerod 2 May 08, 2015 07:43AM |
Re: Commissioning an Ormerod 2 May 26, 2015 04:26PM |
dmould
Ethernet and USB are alternate ways of communicating with the Duet, you do not usually use both at the same time. The initial stages that you are carrying out are easiest done via USB, so leave the ethernet port disconnected for now. Assuming that you selected the correct serial port in the serial monitor, it sounds like your Duet may have lost its firmware (maybe you accidentally pressed the "erase" button on the Duet board at some stage). The aesiest way to ensure that you have selected the correct serial port is to unplug the Duet and ensure that the serial monitor then complains that it cannot connect to that port. Assuming that the Duet has lost its firmware, you therefore need to follow the instructions for flashing new firmware into the board (using Bossac) before you can do anything else. Be aware that after you flash the Ormerod firmware, the Duet will identify itself as a different device on the USB port, and so uses a different driver and will usually come up on a different serial port number, so you will need to change the serial monitor port setting.
Dave
Re: Commissioning an Ormerod 2 May 27, 2015 08:07AM |
Re: Commissioning an Ormerod 2 May 27, 2015 12:00PM |
droftarts
It's also worth trying to connect with Pronterface. Sometimes, Arduino IDE just doesn't see the Duet, but Pronterface does. See: [reprappro.com]
Ian
RepRapPro tech support
Re: Commissioning an Ormerod 2 May 29, 2015 06:12AM |
Re: Commissioning an Ormerod 2 May 29, 2015 07:22AM |
Re: Commissioning an Ormerod 2 May 29, 2015 08:03AM |
dmould
When you flashed it, did it go through the verify stage and report that the firmware was successfully downloaded?
Dave
Re: Commissioning an Ormerod 2 May 29, 2015 08:16AM |
shauna
I've tried using Pronterface, in ports there are options for COM10 and COM4. COM10 is responding "Can't write to printer (disconnected?)." over and over.
Re: Commissioning an Ormerod 2 May 29, 2015 08:46AM |
dc42
That is a sign that Windows thinks the driver is already in use. I think there is a bug in that driver. Remove the USB cable from the computer, then plug it back in again. Then tell Pronterface to connect again to COM10, and see if it says anything different.
Re: Commissioning an Ormerod 2 May 29, 2015 09:55AM |
shauna
dc42
When I unplug it and try to connect I get "[Error2] The system cannot find the file specified"
When I plug the USB back in and try to connect I get "Can't write to printer (disconnected?)." again.
Re: Commissioning an Ormerod 2 June 02, 2015 11:16AM |
Re: Commissioning an Ormerod 2 June 02, 2015 12:06PM |
Re: Commissioning an Ormerod 2 June 02, 2015 01:22PM |
Re: Commissioning an Ormerod 2 June 02, 2015 01:48PM |
Re: Commissioning an Ormerod 2 June 04, 2015 06:09AM |
Re: Commissioning an Ormerod 2 June 04, 2015 06:29AM |
Re: Commissioning an Ormerod 2 June 04, 2015 07:05AM |
zombiepantslol
Your output looks good to me, and it tells me you already have a tool defined. FYI you do this via M563 in your config.g file.
Send "T0" (or T[the number from your M563 P parameter]) to select the tool, then you will see that M105 reports the current temperature as seen in the instructions. Also check out this article.
The H0 and H1 values report the current and target temperatures for all configured heaters. You'd only have to worry about it if no H1 value showed up.
