Z setting help May 07, 2015 07:54PM |
Re: Z setting help May 08, 2015 03:13AM |
Re: Z setting help May 08, 2015 02:16PM |
Re: Z setting help May 10, 2015 12:48PM |
Re: Z setting help May 10, 2015 01:54PM |
Igloo_it
When i ask for x home the motor turn but stop before of the right position and when i try multiple time the motor turn over the end point. Any help will be higly apreciate, thanks.
Re: Z setting help May 10, 2015 01:58PM |
Re: Z setting help May 10, 2015 02:13PM |
Igloo_it
it seems that i solved some problems, one question, why i have to compensate the bed manually and put the values in the bed.g file? it should make the compensation all the time before to start a new job, isn't it?
Re: Z setting help May 10, 2015 02:58PM |
Re: Z setting help May 10, 2015 03:32PM |
Re: Z setting help May 10, 2015 03:53PM |
Re: Z setting help May 10, 2015 05:07PM |
Re: Z setting help May 11, 2015 03:03PM |
dc42
Version 0.78 firmware is very old now. It's time for you to upgrade to something more recent.
Re: Z setting help May 11, 2015 03:39PM |
Igloo_it
dc42
HI dC42 I just uploaded the ver 1.09, now i tried to warm up the bed and hot end but only the bed work, for the hot end this message pop up no tool selected, with the ver 0,78 work normally,thanks
Re: Z setting help May 11, 2015 03:54PM |
dc42
Igloo_it
dc42
Assuming you updated your config.g file for version 1.09, you need to send T0 to select the head first. If you didn't update your config.g file, then it's probably T1 that you need.
Re: Z setting help May 11, 2015 04:05PM |
Re: Z setting help May 11, 2015 04:14PM |
Igloo_it
this is the actual config
M563 P0 D0 H1 ; Define tool 0
G10 P0 S-273 R-273 ; Set tool 0 operating and standby temperatures
Re: Z setting help May 11, 2015 04:24PM |
dc42
Igloo_it
You are defining the hot end as tool 0 (the P parameter in the M563 and G10 commands), so you need to activate Tool 0. Here are some ways of doing it:
1. Send T0 via Pronterface, or via "Send Gcode" on the web interface.
2. Look at the "Heater 1" status on the web interface. It will show the status as Off. Click on it so that it changes to Active.
3. Putting a T0 command at the end of config.g may work (I haven't tried it with 1.09).
4. I recommend that you also include T0 near the start of your slic3r start gcode, to ensure that the head is selected when you start a print.
Re: Z setting help May 11, 2015 04:38PM |
Re: Z setting help May 11, 2015 04:46PM |
Re: Z setting help May 11, 2015 05:03PM |
Igloo_it
i just sent a job and i need an information, when the start the compensation the head go down to the bed like the Z home or stay a little away from the bed? thanks
Re: Z setting help May 11, 2015 05:16PM |
Re: Z setting help May 12, 2015 03:11PM |
Re: Z setting help May 12, 2015 05:09PM |
Darathy
what i dislike abaut repetier host is: even if it uses slic3r for slicing it doesnt show layer changes on zombies webinterface. but using slic3r alone does, just easyer to see all information abaut the print.
Re: Z setting help May 12, 2015 05:26PM |
shadow651
Darathy
Well, I know the web interface has a glitch right now where if the 1st layer height is 0.5mm it won't show layer changes right..... maybe repetier host is using 0.5mm for the first layer? That should be fixed in the next release.
Honestly, I don't see much point in repetier (For a Duet PCB system) other than 3D gcode previews outside of slic3r. But even then I've found that some free gcode simulators are better ways to preview the gcode anyways.
Re: Z setting help May 14, 2015 02:34PM |
Re: Z setting help May 14, 2015 03:44PM |
Igloo_it
yesterday finally i set up the first printer, today i tried a new job and the hot end not warm up, any idea on where i have to check? the bed work ok, thanks
Re: Z setting help May 14, 2015 03:49PM |
Darathy
shadow651
Darathy
I dont know ,but i thought it used slic3r settings for layer hight? ,i have first layer hight set to 100% of the rest and have never printed above 0.3mm layer hight.
But slic3r 1.2.6 has preview aswell now so i use it mostly ,still miss estimate print time on it tho
Re: Z setting help May 14, 2015 03:55PM |
Darathy
And Cura is not even working, all i get is just moves withought any extrusion(temp stays at 0 and extruder doesnt move) i have tried editing start code but with no change
Darathy
...seems its generating wrong code (M109 instead of M104).
Re: Z setting help May 14, 2015 04:00PM |
Re: Z setting help May 15, 2015 02:25PM |
dc42
Igloo_it
1. Have you sent a T0 command to enable the hot end?
2. Does the LED near the hot end connector light up when you tell then hot end to heat up?
3. If yes to (2), check the 6-pin hot end connector. IMO it's not a very good connector (assuming RRP hasn't changed it since my Ormerod 1 kit). It's quite easy to fail to push the pins fully home into the shells. Another possibility is poor crimp connections on the pins.
