A circle should be a circle, shouldn't it? May 15, 2015 04:24PM |
Re: A circle should be a circle, shouldn't it? May 15, 2015 05:07PM |
Re: A circle should be a circle, shouldn't it? May 15, 2015 06:55PM |
Re: A circle should be a circle, shouldn't it? May 16, 2015 03:24AM |
Re: A circle should be a circle, shouldn't it? May 16, 2015 06:08AM |
Re: A circle should be a circle, shouldn't it? May 16, 2015 06:30AM |
Re: A circle should be a circle, shouldn't it? May 16, 2015 02:10PM |
Re: A circle should be a circle, shouldn't it? May 17, 2015 05:46AM |
Re: A circle should be a circle, shouldn't it? May 17, 2015 07:33AM |
Re: A circle should be a circle, shouldn't it? May 17, 2015 07:41AM |
Re: A circle should be a circle, shouldn't it? May 17, 2015 07:45AM |
Re: A circle should be a circle, shouldn't it? May 17, 2015 07:53AM |
Darathy
Strange ,i am using Slic3r 1.2.6 and when i printed benchy some sizes were as described but some were off by 0.3 ,i still think its a calibration issue tho ,i havent tested with Cura yet but will soon.
Re: A circle should be a circle, shouldn't it? May 17, 2015 09:29AM |
Treito
Darathy
The strange think is that using Slic3r 1.1.7 also hits the dimensions, but Slic3r 1.2.6 seems to differ roughly 0.3-0.5mm.
Be careful testing Cura as it only supports absolute Extruder length. If you try to pause the print the filament will be unloaded if you do not modify your commands.
Re: A circle should be a circle, shouldn't it? May 17, 2015 11:06AM |
Re: A circle should be a circle, shouldn't it? May 17, 2015 11:28AM |
Re: A circle should be a circle, shouldn't it? May 17, 2015 11:51AM |
Re: A circle should be a circle, shouldn't it? May 17, 2015 11:53AM |
Re: A circle should be a circle, shouldn't it? May 17, 2015 03:56PM |
Re: A circle should be a circle, shouldn't it? May 17, 2015 03:59PM |
Treito
I have an idea for this problem.
I redrawed an object new and I sliced it new (changed from Cura to Slic3r). The first time I got some errors using Slic3r but this time everything was alright. But then I could watch a strange phenomena: My problems rotated by 45°. Now the length of the X axis and Y axis did not fit but the diagonals.
And also the inner circle seemed to nearly fit (320mm - max. 0.1mm)
I think that the reason is the small bearing of the X runner mount. I can not manage it to get close enough to the acrylic arm. So my nozzle is not straight 90° to the bed. At first this does not matter but if the nozzle slides over the printing the angle can change. According to where the layer starts this could explain my problem, maybe. But it will take some time to test this.
Re: A circle should be a circle, shouldn't it? May 17, 2015 04:12PM |
Darathy
The weight of the HotEnd should push the bearing against the acrylic ,check that the cable is not pulling it up.
Re: A circle should be a circle, shouldn't it? May 26, 2015 04:16AM |
Re: A circle should be a circle, shouldn't it? May 26, 2015 04:42AM |
Treito
...Something is also strange. If I open the original parts from the Ormerod 1 for example the extruder gear, Slic3r tells me that the X and Y dimensions are different....
Re: A circle should be a circle, shouldn't it? May 26, 2015 05:02AM |
Re: A circle should be a circle, shouldn't it? May 26, 2015 05:32AM |
Treito
...Slic3r tells me that the dimensions are 17.00x16.96x53.00. And there are no teeth...
Re: A circle should be a circle, shouldn't it? May 26, 2015 06:02AM |
Re: A circle should be a circle, shouldn't it? May 26, 2015 06:52AM |
Treito
What software do you use?
BTT: But why my circles are not circles in the center of the bed but they are circles at the edges of the bed you cannot answer, right? Anybody else? Where I have to look for this error?
Re: A circle should be a circle, shouldn't it? May 26, 2015 07:06AM |
Re: A circle should be a circle, shouldn't it? May 26, 2015 07:25AM |
Re: A circle should be a circle, shouldn't it? May 26, 2015 07:28AM |
Re: A circle should be a circle, shouldn't it? May 26, 2015 08:15AM |
