Spring loaded extruder is not working (for me) June 21, 2015 03:11AM |
Re: Spring loaded extruder is not working (for me) June 21, 2015 05:00AM |
Re: Spring loaded extruder is not working (for me) June 21, 2015 05:04AM |
Re: Spring loaded extruder is not working (for me) June 21, 2015 06:24AM |
Re: Spring loaded extruder is not working (for me) June 21, 2015 07:46AM |
Treito
...I used a ball point spring and a long screw so I am able to get every tension I need from low to high...
Re: Spring loaded extruder is not working (for me) June 21, 2015 09:16AM |
Re: Spring loaded extruder is not working (for me) June 21, 2015 10:26AM |
Treito
..So you think it is really only the spring?...
..What happens if you give resistance to your extrusion?..
Re: Spring loaded extruder is not working (for me) June 21, 2015 10:39AM |
Re: Spring loaded extruder is not working (for me) June 21, 2015 11:45AM |
Re: Spring loaded extruder is not working (for me) June 21, 2015 12:03PM |
Re: Spring loaded extruder is not working (for me) June 21, 2015 12:27PM |
Re: Spring loaded extruder is not working (for me) June 21, 2015 01:15PM |
Treito
So I found some springs with
spring wire diameter 0.8mm
spring, outside diameter 5,7mm
spring length (relaxed) 25mm
Re: Spring loaded extruder is not working (for me) June 21, 2015 02:03PM |
Re: Spring loaded extruder is not working (for me) June 21, 2015 02:09PM |
VortyZA
Thanks for the comments Erik etc. - I would imagine that many ballpoint pen springs would be weaker than the ones I originally used when testing the extruder.
The grip shown in Erik's photo of the filament is the perfect amount in my opinion - it won't wear through the filament but grabs it tightly.
Re: Spring loaded extruder is not working (for me) June 22, 2015 03:24PM |
Re: Spring loaded extruder is not working (for me) June 23, 2015 05:19AM |
Re: Spring loaded extruder is not working (for me) June 23, 2015 07:09AM |
Re: Spring loaded extruder is not working (for me) June 24, 2015 02:02AM |
Re: Spring loaded extruder is not working (for me) June 24, 2015 06:23AM |
Re: Spring loaded extruder is not working (for me) June 24, 2015 07:25AM |
Re: Spring loaded extruder is not working (for me) June 24, 2015 02:18PM |
Re: Spring loaded extruder is not working (for me) June 24, 2015 02:34PM |
Re: Spring loaded extruder is not working (for me) June 24, 2015 03:48PM |
Re: Spring loaded extruder is not working (for me) June 24, 2015 05:24PM |
Re: Spring loaded extruder is not working (for me) June 25, 2015 11:31AM |
Re: Spring loaded extruder is not working (for me) June 25, 2015 11:53AM |
Treito
..But I may need longer screws for better handling. ...
Re: Spring loaded extruder is not working (for me) June 25, 2015 11:56AM |
Re: Spring loaded extruder is not working (for me) June 26, 2015 03:12PM |
Re: Spring loaded extruder is not working (for me) July 04, 2015 12:50PM |
