Broken fan spacer August 26, 2015 02:28AM |
Re: Broken fan spacer August 26, 2015 03:46AM |
Re: Broken fan spacer August 26, 2015 11:31AM |
Re: Broken fan spacer August 26, 2015 12:49PM |
Re: Broken fan spacer August 26, 2015 01:26PM |
Re: Broken fan spacer August 26, 2015 01:28PM |
Re: Broken fan spacer August 26, 2015 03:27PM |
Re: Broken fan spacer August 26, 2015 05:03PM |
Re: Broken fan spacer August 26, 2015 08:46PM |
Darathy
heres the STL of the spacer if you need:
Re: Broken fan spacer August 27, 2015 06:14AM |
Re: Broken fan spacer August 27, 2015 03:06PM |
Re: Broken fan spacer August 27, 2015 06:36PM |
Re: Broken fan spacer August 28, 2015 07:22AM |
Re: Broken fan spacer August 28, 2015 10:01AM |
Darathy
I just opened it in solidworks(it was in an old ormerod-master folder i had) and saved as stl. If you need i can add some other parts if you need
Re: Broken fan spacer August 28, 2015 01:35PM |
Re: Broken fan spacer August 28, 2015 01:46PM |
Re: Broken fan spacer August 28, 2015 01:49PM |
Re: Broken fan spacer August 28, 2015 04:58PM |
Re: Broken fan spacer August 28, 2015 05:17PM |
Re: Broken fan spacer August 29, 2015 01:31AM |
Re: Broken fan spacer August 29, 2015 07:45AM |
whitebluff
I've installed my printed part. It works okay, The part that's needed to push into duct is a little shorter than the original laser cut part. But, it works.
Re: Broken fan spacer August 29, 2015 08:00AM |
I think most users do not know how this works. I had to asked ZPL before I knew it.Quote
ormerod168
create link in message[/i]
Re: Broken fan spacer August 29, 2015 08:16AM |
Re: Broken fan spacer August 29, 2015 08:39AM |
Re: Broken fan spacer August 29, 2015 03:33PM |
Re: Broken fan spacer August 29, 2015 03:53PM |
0x0000
There's one buried in the Github repository under a previous tag. If I recall, someone from RepRap said in another thread that not everything has been exported to DXF in the master branch
