Re: New firmware 1.09k-dc42 December 20, 2015 12:29PM |
Re: New firmware 1.09k-dc42 December 20, 2015 12:52PM |
Re: New firmware 1.09k-dc42 December 21, 2015 03:05AM |
Re: New firmware 1.09k-dc42 December 21, 2015 03:32AM |
Mak64
Hi
Since I installed the new slic3r 1.2.9, the printing % slide does not work anymore 'correctly.
This morning I installed the new firmware 1.09m (until now I had the 0.78x) to see if things improve. Now the "object height2 is ok, but the printing % slide still does not work for me.
I use Firefox 43.0.1
Does anyone have the same problem? I read a lot on the forum, but did not find much on this problem.
Thank
Re: New firmware 1.09k-dc42 December 21, 2015 06:04AM |
Re: New firmware 1.09k-dc42 December 21, 2015 08:08AM |
Mak64
dc42
On the GCode Files tab of the web interface, what does it say for that file in the Filament Usage column?
- 11080.4 mm.
Mak64
With the new web interface it is possible by drag & drop printing without saving on sd as in the old version?
Re: New firmware 1.09k-dc42 December 21, 2015 09:12AM |
Re: New firmware 1.09k-dc42 December 21, 2015 11:23AM |
Mak64
dc42
Do you have slic3r configured for relative or absolute extrusion?
Where is this setting ?
If is the "use relative E distances" in "printer setting" tab is unmarked.
Re: New firmware 1.09k-dc42 December 21, 2015 12:55PM |
dc42
Yes it's that one. Relative extruder distances are recommended because they avoid rounding errors, and that's what most Duet user use. The code in my fork that returns print status information assumes you use relative extruder distances. However, in my forthcoming 1.09o release, the print status information is correct if you use absolute extruder distances too.
Re: New firmware 1.09k-dc42 December 21, 2015 03:19PM |
Re: New firmware 1.09k-dc42 December 21, 2015 07:12PM |
Re: New firmware 1.09k-dc42 December 24, 2015 10:45AM |
Re: New firmware 1.09k-dc42 December 24, 2015 11:07AM |
Versia
Hello,
When I use your firmware with the Pronterface, after I start the SD print and check the "watch" option, the Pronterface command line continues to show "Not SD printing". what's the possible cause?
Re: New firmware 1.09k-dc42 December 24, 2015 03:36PM |
dc42
The reason it's a beta is that I think there is still a bug in the extruder pressure advance, but nobody uses that yet.
Re: New firmware 1.09k-dc42 December 25, 2015 01:29AM |
dc42
It's because Pronterface is only designed to work with a specific version of Marlin and is very fussy about what responses it gets. However thought it was fixed in 1.09m. Try 1.09o beta 2, available at [dl.dropboxusercontent.com]. The reason it's a beta is that I think there is still a bug in the extruder pressure advance, but nobody uses that yet.
M563 P0 D0 H1 ; Define tool 0 -> M563 P1 D0 H1 ; Define tool 0 G10 P0 S0 R0 ; Set tool 0 operating and standby temperatures -> G10 P1 S0 R0 ; Set tool 0 operating and standby temperatures T0 ; select first hot end -> T1 ; select first hot endin the config.g.
T0; Select extruder -> T1; Select extruderin the gcode file that I want to print.
Re: New firmware 1.09k-dc42 December 25, 2015 01:52AM |
Re: New firmware 1.09k-dc42 December 25, 2015 06:34AM |
dc42
Re: New firmware 1.09k-dc42 December 25, 2015 04:13PM |
Treito
dc42
Can somebody explain to me what this feature is good for? It sounds interesting.
Re: New firmware 1.09k-dc42 December 25, 2015 09:28PM |
Re: New firmware 1.09k-dc42 February 24, 2016 04:10AM |
Re: New firmware 1.09k-dc42 February 25, 2016 02:59AM |
Re: New firmware 1.09k-dc42 February 25, 2016 03:33AM |
Re: New firmware 1.09k-dc42 February 25, 2016 04:16AM |
Re: New firmware 1.09k-dc42 February 27, 2016 03:09AM |
Re: New firmware 1.09k-dc42 February 27, 2016 04:14AM |
Re: New firmware 1.09k-dc42 March 04, 2016 07:28AM |
Re: New firmware 1.09k-dc42 March 04, 2016 07:57AM |
Re: New firmware 1.09k-dc42 June 11, 2016 04:54AM |
dc42
The RRP version is here [github.com]. Alternatively, search for the thread I created about 2 years ago on patching Pronterface to not wait for OK, and apply a similar patch to the latest Pronterface source code.
Re: New firmware 1.09k-dc42 June 11, 2016 05:12AM |
Luke_Duckwalker
...And I couldn't find also the post you referred to manually patch pronterface.
Re: New firmware 1.09k-dc42 June 11, 2016 06:07AM |
