Some questions about the design September 25, 2015 01:51PM |
Re: Some questions about the design September 25, 2015 03:30PM |
Re: Some questions about the design September 25, 2015 03:58PM |
Re: Some questions about the design September 26, 2015 03:31AM |
Re: Some questions about the design September 26, 2015 05:19AM |
Re: Some questions about the design September 26, 2015 06:49AM |
Treito
....Especially the x-axis belt is hard to span. This would be a reason for my bad circles...
Re: Some questions about the design September 26, 2015 07:00AM |
Re: Some questions about the design September 26, 2015 12:30PM |
Re: Some questions about the design September 26, 2015 12:42PM |
dc42
My procedure for tensioning the X belt is:
1. Loosen the X motor screws a lot.
2. With one hand, hold the body of X motor so as to keep the belt taught, while you tighten up the outer X motor screw using the other hand. The belt will be pulling on the pulley so that the X motor is at an angle.
3. Then tighten the inner X motor screw. This will pull the X motor into the correct orientation, tightening the belt as it does so.
Re: Some questions about the design September 29, 2015 11:13AM |
Re: Some questions about the design September 29, 2015 01:56PM |
