Hello,
i get some problems with my two 0.3 nozzle (one is an original ormerod2 spare part 0.3 nozzle and another is an e3dv6 cheap clone).
Extrusion get stuck when i print .. the filament slip on the hobbed insert , too many pressure i presume
I use an homemade Styron abs 1.75 filament but i've tryed with a know to work commercial filament, same problem.
I've swapped the original pla extruder part with an abs part and even a spring loaded abs part but nothing changes.
I've already disassembled the extruder, cleaned the hobbed insert, disassembled the nozzles, cleaned them with high temperature and a guitar string ... i'm a bit lost ...
I've noticed that if i extract abs at 240C with the web interface (10mm at 5mm/sec), filament start to slip in the extruder, is this normal ? with 0.5 extrusion was ok but sadly i cannot test with 0.5 as i've destroyed the nozzle :x, can someone please confirm me that with ABS and a 0.3 nozzle the command "extract 10MM at 5mm/sec speed" work without problem ?
Edit : does the hobbed insert can wear out ?
Regards
Florent
Edited 1 time(s). Last edit at 10/18/2015 04:28PM by dapsaille.
