Re: More display options for PanelDue November 18, 2015 06:38AM |
dougal1957
Do I remember you saying that RAM was running short could you maybe use the onboard SD Card to store any buffers for the cmd input and anything else that may need to be stored.
Re: More display options for PanelDue November 18, 2015 04:39PM |
Re: More display options for PanelDue November 19, 2015 11:03AM |
Re: More display options for PanelDue November 19, 2015 12:13PM |
Re: More display options for PanelDue November 19, 2015 12:54PM |
Re: More display options for PanelDue November 19, 2015 01:28PM |
Re: More display options for PanelDue November 19, 2015 02:49PM |
chrishamm
That's quite a lot, in fact that's almost as much as on my web interface TODO list!
The M408 responses provide the current fan value, but at the moment only one single fan is supported and I'm seriously wondering if there is any good reason to add support for another one at this time. I for one haven't heard of anyone who uses a second controllable fan with the Duet 0.8.5 yet, but feel free to tell me if support for the web interface and/or PanelDue has been requested. I really wouldn't be happy with changing the data format of the particular field in the status response, because it would break backward-compatibility with older versions, although I'd still find that better than introducing yet another field for this purpose.
I may add support for multiple fans in a future web interface release, but certainly not within the next two or three versions.
Re: More display options for PanelDue November 20, 2015 07:29AM |
dc42
Although I tend to agree with you, I'm not sure there is any point having two print cooling fans.
Re: More display options for PanelDue November 20, 2015 10:45PM |
Re: More display options for PanelDue November 20, 2015 11:10PM |
Re: More display options for PanelDue November 21, 2015 03:03AM |
coogrrr
Dave, Chris, Doug.... Little help please.... I got my 7" LCD I also made the wire connection on the back of the controller board. I have downloaded the latest firmware and I am sure I have been told somewhere about the bossac program... Can you give a quick 1 2 3 on loading this with the firmware?
Thanks in advance!
James
Re: More display options for PanelDue November 21, 2015 10:41AM |
dc42
How about having the web interface check whether the returned fan value is an array or not, and if it is, just pick the first element?
Re: More display options for PanelDue November 21, 2015 01:10PM |
Re: More display options for PanelDue November 21, 2015 01:41PM |
dc42
1. Please increment the version number every time you publish a change. Otherwise it's hard for users to know whether they are running the latest version.
dc42
2. I have a report that the Load Filament function screws up if extrusion is set to absolute (e.g. because you just used Cura to print something). Please put an M83 command at the start of the sequence if you don't already, ore else a G92 E0 before each extrusion command.
dc42
3. When starting a file upload, please pass the file size to the Duet along with the filename. That will hopefully help me to speed up file upload some more.
Re: More display options for PanelDue November 21, 2015 01:46PM |
Re: More display options for PanelDue November 21, 2015 02:03PM |
Re: More display options for PanelDue November 21, 2015 02:55PM |
dougal1957
coogrrr
Thanks in advance!
James
I made a little batch file for this (Attached) you will need to put it in the same directory with Bossac and the firmware file You will also need to edit it for the correct com port that device manager says the bossa port is on once you connect the PanelDue controller to the PC and erase it.
Hope this helps
Doug
ps you can also see full details on DC42's PanelDUE Blog
Re: More display options for PanelDue November 21, 2015 03:24PM |
Re: More display options for PanelDue November 21, 2015 03:50PM |
Re: More display options for PanelDue November 21, 2015 03:58PM |
Re: More display options for PanelDue November 21, 2015 04:02PM |
Re: More display options for PanelDue November 21, 2015 04:05PM |
Re: More display options for PanelDue November 22, 2015 11:25AM |
chrishamm
dc42
Are you referring to the documentation or to the status response itself? DWC v1.07 should work with the old protocol standard as well (it tries to maintain backward-compatibility), but certain features won't work well if some fields are missing. I can add a note to the wiki page of the status responses and list which changes have been made since I originally introduced them, if that's okay for you. If you mean a version field in the status response, I suggest to wait until a field format changes which may eventually break backward-compatibility.
Re: More display options for PanelDue November 26, 2015 03:37AM |
Re: More display options for PanelDue November 26, 2015 04:10AM |
Re: More display options for PanelDue November 26, 2015 05:55AM |
Re: More display options for PanelDue November 27, 2015 04:09AM |
Re: More display options for PanelDue November 27, 2015 04:25AM |
Treito
Can you please tell me the costs for two PanelDue including VAT and shipping to Germany? What are the payment methods? Is Paypal okay? I need an offer to make my final decision.
Re: More display options for PanelDue November 27, 2015 09:50AM |
Re: More display options for PanelDue November 30, 2015 02:57PM |
