How to fix an aluminium X-arm-kit with an unwanted groove December 31, 2015 12:17PM |
Re: How to fix an aluminium X-arm-kit with an unwanted groove December 31, 2015 02:45PM |
Re: How to fix an aluminium X-arm-kit with an unwanted groove December 31, 2015 03:01PM |
Re: How to fix an aluminium X-arm-kit with an unwanted groove January 01, 2016 09:44AM |
Treito
The problem is caused by the bearing of the X-carriage. One problem is that it is a little bit too small and it may be not aligned to the running surface so the contact area is only the edge of the bearing. So it is like a knife as aluminium is weaker than stainless steel.
The second problem is the washer between the bearing and the x-carriage. Especially if you use the original bearing MR93ZZ it is important that the totally flat side of the washer is heading to the X-carriage
be careful as the glue prevents very fast to align the shim any further and..
Re: How to fix an aluminium X-arm-kit with an unwanted groove January 01, 2016 10:08AM |
Re: How to fix an aluminium X-arm-kit with an unwanted groove January 01, 2016 10:34AM |
Re: How to fix an aluminium X-arm-kit with an unwanted groove January 01, 2016 10:47AM |
Re: How to fix an aluminium X-arm-kit with an unwanted groove January 01, 2016 11:01AM |
Darathy
i used epoxy and put as thin as i could and put cloth clipers through all the lenght and it still pushed quite a bit of glue out.
Re: How to fix an aluminium X-arm-kit with an unwanted groove January 01, 2016 11:12AM |
