Re: How to wire up a Duet 0.8.5? January 25, 2016 03:56AM |
Re: How to wire up a Duet 0.8.5? January 25, 2016 04:01AM |
Re: How to wire up a Duet 0.8.5? January 25, 2016 04:06AM |
0x0000
Also, on what material is your Duet mounted? I don't have a stainless steel enclosure and cannot yet print my own.
Re: How to wire up a Duet 0.8.5? January 25, 2016 07:15PM |
Re: How to wire up a Duet 0.8.5? January 25, 2016 09:55PM |
Treito
0x0000
Ahm.. I do not like to answer that as it was temporarily solution (for the last 6 months). I needed the MK2 to fix my MK1 and vice versa. I was not able to print my case yet (as I stll need to design it), but it was part of another package of my HDD. At the supermarket you sometimes get your eggs in such kind of material. But hey even screws fits. I am far far away of beeing lucky with that and I soon will print my own case. My MK1 will be rebuild as MK2, too. I already switched the PSU and I would like to mount it to the printer.
Re: How to wire up a Duet 0.8.5? January 25, 2016 11:17PM |
PRZ
It is only very recently that created the page about crimping on the wiki that you referred to [reprap.org], so that is the reason it may not yet be well referenced.
Treito, your photos are nice, can I reuse them on the Reprap Wiki ? The documentation licence on the wiki is GFDL 1.2. And if you could allow a double licencing with CC BY-SA, that may spreed on a larger scope (that is Wikipedia licensing and a lot of personal sites also).
Re: How to wire up a Duet 0.8.5? January 28, 2016 02:33AM |
Re: How to wire up a Duet 0.8.5? January 28, 2016 08:29AM |
Re: How to wire up a Duet 0.8.5? January 28, 2016 10:35AM |
Re: How to wire up a Duet 0.8.5? January 29, 2016 03:44AM |
0x0000
I found some ferrules @Treito. I hope these make you less sick!
2.5mm ferrules. I tried with 25A cable, but it wouldn't fit into the ferrule. This is 15A and thicker than the previous ones. 20A wasn't available:
[attachment 71007 big-ferrules.jpg]
0.75mm ferrules, which were the smallest I could get.
[attachment 71006 little-ferrules.jpg]
The big ones are in there VERY tight - there's no way those are coming out unless I unscrew them myself. I can't believe I tried to do this without them! However, the little ones on the hotend don't seem to fit into the terminals. I had to pinch the tips a little bit with pliers to get them where they are now, and the screws do seem to be holding them in place. Do those look OK, or should I try harder?
Re: How to wire up a Duet 0.8.5? January 29, 2016 08:29PM |
Re: How to wire up a Duet 0.8.5? January 30, 2016 02:36AM |
Re: How to wire up a Duet 0.8.5? January 30, 2016 02:54AM |
Re: How to wire up a Duet 0.8.5? January 30, 2016 03:14AM |
dc42
Unfortunately, different stepper motor manufacturers use different pinouts on the stepper motors. I bought looms from Robotdigg to make a printer, and I had to swap a couple of wires in each loom to make them work with the motors I had. Then I switched to a different make of motor and I had to swap them all back again. It's easy to do, just disengage the barb on the crimp pin and pull it out. Do this for the two inner pins of the 4 pin connector, then push them back in the other way round.
Re: How to wire up a Duet 0.8.5? February 04, 2016 04:59PM |
Re: How to wire up a Duet 0.8.5? February 04, 2016 06:28PM |
Fpex
Guys, how can i wire up the stock RRP bed level sensor to this duet and why is that my ned and hot end temps are so wrong? Can somebody share a config file for this board?
Thanks
PC10 replaces AD14 from the Duet 0.6:
Orange/red = AD12
Yellow = GND
Blue = PC10
Green = 3V3
Re: How to wire up a Duet 0.8.5? February 05, 2016 01:29AM |
Re: How to wire up a Duet 0.8.5? February 05, 2016 02:57AM |
Re: How to wire up a Duet 0.8.5? February 05, 2016 12:50PM |
Re: How to wire up a Duet 0.8.5? February 05, 2016 02:19PM |
Re: How to wire up a Duet 0.8.5? February 05, 2016 02:34PM |
Fpex
My 0.8.5 is properly wired now and config.g ok.
Thanks guys. I hate flying wires, but this is a temporary thing to see if my duet0.6 is broken
Anybody has designed a case for the 0.8.5 (with and without 4x board)?
Darathy
i'm still trying to design one, but atm making not much progress ,i think someone posted nearly finished version in an erlier post on this topic
Re: How to wire up a Duet 0.8.5? February 05, 2016 02:44PM |
Re: How to wire up a Duet 0.8.5? February 05, 2016 03:40PM |
Re: How to wire up a Duet 0.8.5? February 05, 2016 04:53PM |
Re: How to wire up a Duet 0.8.5? February 05, 2016 05:06PM |
Re: How to wire up a Duet 0.8.5? February 05, 2016 05:56PM |
Re: How to wire up a Duet 0.8.5? February 05, 2016 05:58PM |
Re: How to wire up a Duet 0.8.5? February 06, 2016 02:23AM |
Re: How to wire up a Duet 0.8.5? February 06, 2016 02:25AM |
Re: How to wire up a Duet 0.8.5? February 06, 2016 02:27AM |
