"Auto Bed Compensation" problems using DC42 IR Z Probe January 30, 2016 06:18PM |
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe January 30, 2016 06:33PM |
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe January 30, 2016 07:32PM |
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe January 30, 2016 07:47PM |
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe January 31, 2016 01:33AM |
M558 P1 ; Use a simple modulated Z probe (change to P1 for an intelligent Z probe)
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe January 31, 2016 02:24AM |
AJAX alert - SyntaxError: Unexpected token a
Chrome console - Error! The following JSON response could not be parsed:
model.js:972 {"status":"I","coords":{"axesHomed":[1,1,1],"extr":[0.0],"xyz":[nan,nan,nan]},"currentTool":-1,"params":{"atxPower":1,"fanPercent":[0.00,0.00],"speedFactor":100.00,"extrFactors":[100.00]},"seq":284,"sensors":{"probeValue":173,"probeSecondary":[174],"fanRPM":0},"temps":{"bed":{"current":21.1,"active":-273.1,"state":0},"heads":{"current":[20.9],"active":[-273.0],"standby":[-273.0],"state":[1]}},"time":351.2,"coldExtrudeTemp":160,"coldRetractTemp":90,"endstops":0,"geometry":"cartesian","name":"spanky","probe":{"threshold":593,"height":0.80,"type":2},"tools":[{"number":0,"heaters":[1],"drives":[0]}]}
M561 ; Zero any previous bed compensation
G1 Z10 F200 ; Move 10mm off the bed
G1 X40 Y160 F2000 ; *** First probe point
G30 P0 Z-100000 ; Probe the bed
G1 Z10 F200 ; Move back up
G1 X190 Y160 F2000 ; *** Second probe point
G30 P1 Z-100000 ; Probe the bed
G1 X190 Y0 F2000 ; *** Third probe point
G30 P2 Z-100000 ; Probe the bed
G1 X40 Y0 F2000 ; *** Fourth probe point
G30 P3 S Z-100000 ; Probe the bed and use the four measured points to set the bed equation
G4 P1500 ; Pause to give the web interface time to report the points
G1 Z10 ; Move back up
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe January 31, 2016 03:22AM |
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe January 31, 2016 04:30AM |
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe January 31, 2016 04:33AM |
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe January 31, 2016 08:02AM |
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe January 31, 2016 08:08AM |
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe January 31, 2016 12:47PM |
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe January 31, 2016 05:01PM |
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe February 03, 2016 09:26AM |
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe February 03, 2016 11:08AM |
Sergio
The error is reproducible, i will record the traffic and also run M122 after the error, problem is only my limited time...
I will come back to you as quick as possible.
Re: "Auto Bed Compensation" problems using DC42 IR Z Probe February 03, 2016 11:28AM |
