New RepRapFirmware 1.09x-dc42 March 13, 2016 09:31AM |
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 09:45AM |
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 10:43AM |
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 12:20PM |
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 12:42PM |
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 12:59PM |
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 01:18PM |
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 02:39PM |
Re: New RepRapFirmware 1.09x-dc42 March 13, 2016 07:56PM |
percar
Hi
I have been following the new build instructions for Duet Firmware following the instructions embedded in the firmware zip
The issues i have been having are as follows
I installed eclipse without issue
I started eclipse and created workspace C:/Eclipse/Firmware
I closed eclipse
I downloaded and unzipped RepRapFirmware-dev and placed into C:/Eclipse/Firmware then renamed to RepRapFirmware
I downloaded and uinzipped CoreDuet-dev and unzipped into C:/Eclipse/Firmware then renamed to CoreDuet
I started eclipse
this is where the issues start
I did not see either project in the project tree.....did I miss something
percar
I did try to use (file/new/MakeFile Project With Existing Code)....this made the project visible in the project tree
I then received 2 errors
Program "g++" not found in PATH CoreDuet [Discovery Options] page in project properties C/C++ Problem
Program "gcc" not found in PATH CoreDuet [Discovery Options] page in project properties C/C++ Problem
I assumed that perhaps there was an issue with the gcc-arm-none-eabi-4.8.3-2014qi\bin file so I tried to check it in the C/C++ Build -> Settings -> Cross Settings.
When i got to the gui for that setting there is nothing that i am able to change maybe im missing something......i would appreciate any help
Re: New RepRapFirmware 1.09x-dc42 March 14, 2016 04:47AM |
Re: New RepRapFirmware 1.09x-dc42 March 14, 2016 11:12AM |
Re: New RepRapFirmware 1.09x-dc42 March 14, 2016 12:10PM |
Fpex
I admit I do not use Eclips (I am not fond of it), To install the firmware what do i need? the C version?
Re: New RepRapFirmware 1.09x-dc42 March 14, 2016 01:54PM |
Re: New RepRapFirmware 1.09x-dc42 March 14, 2016 02:06PM |
Re: New RepRapFirmware 1.09x-dc42 March 14, 2016 04:44PM |
Re: New RepRapFirmware 1.09x-dc42 March 14, 2016 06:14PM |
bobtidey
I have also had a go at building from the two new projects and also get stuck with " not found in PATH " errors for gcc g++.
This is with eclipse and arduino1.5.8. I could edit the Cross Compiler path to the actual arduino bin folder but doesn't seem to help.
The Path under Environment variables also looks good.
Re: New RepRapFirmware 1.09x-dc42 March 14, 2016 06:23PM |
Fpex
The move to eclipse, does it means you are moving out of the arduino way of doing things ?[/quote
RepRapFirmware was built with Eclipse, not Arduino, before I got involved with it. The Arduino IDE is very primitive and totally inadequate for handling large projects such as RepRapFirmware. The move I have made is to stop using a heavily-patched and extended Arduino Due core, and use a separate project (CoreDuet) derived from it instead. At the same time, the build system no longer uses the Arduino plugin for Eclipse, which caused a number of problems, and instead builds RepRapFirmware as a Cross Gcc project.
Re: New RepRapFirmware 1.09x-dc42 March 15, 2016 02:25AM |
Re: New RepRapFirmware 1.09x-dc42 March 15, 2016 03:05AM |
appjaws1
Did you have any thoughts on this error?
Can't rename file or directory /sys/RepRapFirmware-1.09x-dc42.bin to /sys/RepRapFirmware.bin
Re: New RepRapFirmware 1.09x-dc42 March 15, 2016 07:15AM |
dc42
bobtidey
You need to have the cross compiler path set to the \hardware\tools\gcc-arm-none-eabi-4.8.3-2014q1\bin folder, and the cross compiler prefix set to arm-none-eabi-. Both are in the Cross Settings.
Re: New RepRapFirmware 1.09x-dc42 March 15, 2016 11:53AM |
Re: New RepRapFirmware 1.09x-dc42 March 16, 2016 10:30AM |
Re: New RepRapFirmware 1.09x-dc42 March 16, 2016 07:11PM |
Re: New RepRapFirmware 1.09x-dc42 March 17, 2016 06:59AM |
Re: New RepRapFirmware 1.09x-dc42 March 17, 2016 07:56AM |
Re: New RepRapFirmware 1.09x-dc42 March 17, 2016 09:44AM |
Re: New RepRapFirmware 1.09x-dc42 April 11, 2016 09:58AM |
Re: New RepRapFirmware 1.09x-dc42 April 11, 2016 05:02PM |
Re: New RepRapFirmware 1.09x-dc42 April 12, 2016 07:40AM |
Re: New RepRapFirmware 1.09x-dc42 April 13, 2016 02:05AM |
