Firmware/web feature suggestion April 18, 2016 07:27AM |
Re: Firmware/web feature suggestion April 18, 2016 09:11AM |
Re: Firmware/web feature suggestion April 18, 2016 09:57AM |
Re: Firmware/web feature suggestion April 19, 2016 06:56AM |
fotomas
Already works in dc42's firmware.
Set z-movements to half Height to get small enough adjustments.
So during the first layer I sometimes adjust the height. This allows for much preciser adjustment than a sheet of paper and the trial and error time is virtually none.
The problem is to remember the number of adjustments and modifying the config.g, I always forget.
Re: Firmware/web feature suggestion April 19, 2016 02:28PM |
Re: Firmware/web feature suggestion April 20, 2016 06:38AM |
Yes, that should work. My idea was to write macros that bumped Z up or down: e.g.Quote
Darathy
I usualy press the -/+ 0.05 in Z direction in the webinterface then send G92 z0.2 or whatever your first layer hight is.
Re: Firmware/web feature suggestion April 20, 2016 02:09PM |
Re: Firmware/web feature suggestion April 21, 2016 08:19AM |
