Source for STL for part 741 Quick-set hot end fan spacer?
December 30, 2016 08:15AM
Hello,
Because I've been having problems with overhangs curling up, I'd like to add a cooling fan to my Ormerod 2, model 528.2 with the older 'one piece stainless steel nozzle'.
I've printed the part 1123 cooling fan duct [github.com], but now realise I have no way to mount it to my device.
In the instructions for the Quick-set hot end assembly [reprappro.com], I saw that there is a part '741 Quick-set hot end fan spacer' which the cooling fan duct mounts to. This part looks a neat way of mounting the fan to my printer with the minimum of alterations.
Questions, can anyone help?:
Will the quick-set hot end fan spacer fit the rest of my machine?
If so, does anyone have an STL for the '741 Quick-set hot end fan spacer' which I could print on my Ormerod?
I know there are other cooling solutions available, but I'd like to try the RepRapPro version first- it looks tidy.
Many thanks, and happy new year to you all.
gwild
Edited 1 time(s). Last edit at 12/30/2016 08:32AM by gwild.
Re: Source for STL for part 741 Quick-set hot end fan spacer?
December 30, 2016 07:35PM
Hi gwild
I believe the part you are talking about is usually supplied as laser cut acrylic part.
It can be found in the reprappro github repository Quick-set-hot-end.
There are solidworks format files for it and I think a dxf format one as well in a DXF/ directory.
But here is a zipp'ed file containing a .stl format file of the solidworks part, I have not used this personally, so have no idea if a printed version is a good idea or will fit your machine.
You'll have to print it and see what the fit is like, someone else here may have done this already.
Hope this helps.
Lloyd
open | download - 741.zip (36.4 KB)
December 30, 2016 07:53PM
Hi
You might also find this thread useful Broken fan spacer.
It also has various stl files for this part.
Lloyd
December 31, 2016 06:55AM
I have printed it and works great .even better then acrylic which was brittle.
December 31, 2016 08:01AM
gwild
Hello,
gwild
Yes cooling is important but also the stretch of hot filament, e.g. think of the extruded filament as rubber bands added upon each others like outer layers, if you stretch them before adding they will try to curl up, if you push them out they will have no power left to retract, reduce stretching by slowing the speed (esp. reduce speed at small perimeters) and most importantly: ad to the extrusion width (push out the filament) - when slicing for overhangs, go for at least 1.5 x nozzle size, or better, 1.5 x the free extruded filament, this way you should be able to print at least 70 degrees overhang without any curl-ups
Printed on Ormerod 1
Erik
January 01, 2017 05:44PM
Thanks, I'll print and have a go mounting.
Erik, what circular cooling duct are you using in your photo 'overhang_test4.JPG'? I've looked on [reprap.org] but can't see it. It looks interesting- after I mounted a cooling fan, I can see the advantages for cooling from all directions.
Thanks
January 03, 2017 03:38AM
gwild
It's a manually modified version of this one from thingiverse:
[www.thingiverse.com]
Later cut it open for higher airflow and changed the deflector plate to a Tuborg version, much better!
This is how it looked before the cut, it's a very close shave, notice the capacitor of dc42's probe resting against the cooling ring
..and it actually dings against the threaded rod while homing
..and it is resting up against the x-runner bearing
So not a very shareable mod I'm afraid...
Erik
December 06, 2018 07:19PM
Do you not use this fan Duct any more Erik?
December 07, 2018 01:51AM
Karoo Klong
No, it was good, way better than the original setup but did not distribute the air evenly around the nozzle as a proper ring cooler should
..like this one from thingiverse, look at the simulation picture, perfect!
But its way too big to fit the ormerod so I ended up with the Cobra instead and its great
Erik
December 07, 2018 03:01AM
Oh ok.
So a snail fan is the only proper way to go?
An then of course the Cobra rype cooler?
December 07, 2018 03:10AM
ormerod168
gwild
Hello,
gwild
[attachment 88066 overhang_test4.JPG][attachment 88067 IMG_6487-1600.jpg][attachment 88068 IMG_6488-1600.jpg]
Erik
The pistol print looks amazing.
What material did you use for it?
Also what slicer did you use and perhaps settings?
Those supports look like Simplify 3d generated.
December 08, 2018 03:17AM
Karoo Klong
Oh ok.
Yes, to tunnel the air and direct it to the nozzle you need pressure
Yes, that is IMHO the best one possible to fit the ormerod original hotend
Erik
December 08, 2018 03:45AM
Karoo Klong
PLA from Filaprint AFAIR
Simplify3D, 2 perimeters, 40mm/s, layer 0.2mm, infill 30%, temp. bed 62, nozzle 205, support no
It's tinkercad Autodesk Meshmixer generated and included with the model
Erik
Edited 1 time(s). Last edit at 12/08/2018 07:17AM by ormerod168.
December 08, 2018 07:15AM
Karoo Klong
Also here's some Cura setting from another user
Erik
December 08, 2018 08:53AM
ormerod168
Karoo Klong
Oh ok.
Erik
Thank you.
December 08, 2018 08:55AM
ormerod168
Karoo Klong
Ok thanks.
Ill try to impliment that for my Glock 26 Training model.
Erik
December 08, 2018 03:09PM
Karoo Klong
Another option could be to cut the model (you can do that in Sli3er) in two, then glue frame and slide together again with hotglue - done that, trainers for the IPSC newbies :-)
Erik
December 12, 2018 02:41AM
COOL!!!
I was wondering about those ammo boxes. Yours came out perfect.
