Questions concerning upgrading to the new firmware 1.17a January 04, 2017 08:52AM |
Re: Questions concerning upgrading to the new firmware 1.17a January 04, 2017 03:18PM |
Re: Questions concerning upgrading to the new firmware 1.17a January 04, 2017 05:03PM |
Re: Questions concerning upgrading to the new firmware 1.17a January 05, 2017 07:07AM |
Re: Questions concerning upgrading to the new firmware 1.17a January 05, 2017 10:15AM |
sinnedwrong
If I upload DuetWebControl-1.14RC1.zip as in DC42s posting will that enable me to upgrade the firmware on the Arduino to RepRapFirmware-1.17a.bin without touching the Arduino IDE and Bossac? Using my existing configuration I can "upload" for example a .txt file to the sys: folder of the SD card but I can find no other options of where to download to. I suspect that I will have to insert the SD card onto my PC to do this?
sinnedwrong
If I do update the firmware will the Ormerod continue to work without making wiring changes etc.?
sinnedwrong
Is there a list or set of instructions etc. detailing the improvements in the Firmware from the original RepRapPro version and any other things to know. I have seen posts regarding motors going backwards etc. but didn't pay attention at the time.
sinnedwrong
I note that Arduino has released version 1.8.0 of their IDE, are there any compatibility problems known should I have to use the IDE. I only ask as I'm currently building an MPCNC machine that uses Ramps 1.4 and its much more primitive so I'm going to have to download an updated version of the IDE for that. I appreciate using a ".0" version of any software is dangerous
Re: Questions concerning upgrading to the new firmware 1.17a January 06, 2017 01:40PM |
Re: Questions concerning upgrading to the new firmware 1.17a January 06, 2017 05:15PM |
Re: Questions concerning upgrading to the new firmware 1.17a January 08, 2017 09:29AM |
Re: Questions concerning upgrading to the new firmware 1.17a January 08, 2017 12:07PM |
lasse
...Do I have to get Bossac.exe from an earlier version of Arudino and place it on this location manually? I have not found a separate file called Bossac exe on the net.
Lars
Re: Questions concerning upgrading to the new firmware 1.17a January 08, 2017 03:05PM |
Re: Questions concerning upgrading to the new firmware 1.17a January 09, 2017 11:25AM |
Re: Questions concerning upgrading to the new firmware 1.17a January 12, 2017 10:13AM |
Re: Questions concerning upgrading to the new firmware 1.17a January 12, 2017 10:18AM |
Re: Questions concerning upgrading to the new firmware 1.17a January 12, 2017 10:34AM |
Re: Questions concerning upgrading to the new firmware 1.17a January 12, 2017 01:39PM |
Re: Questions concerning upgrading to the new firmware 1.17a January 14, 2017 08:55AM |
Re: Questions concerning upgrading to the new firmware 1.17a January 14, 2017 11:08AM |
Re: Questions concerning upgrading to the new firmware 1.17a January 15, 2017 08:57AM |
Re: Questions concerning upgrading to the new firmware 1.17a January 15, 2017 09:24AM |
Re: Questions concerning upgrading to the new firmware 1.17a January 17, 2017 02:49PM |
Re: Questions concerning upgrading to the new firmware 1.17a January 17, 2017 04:33PM |
Re: Questions concerning upgrading to the new firmware 1.17a January 19, 2017 09:20AM |
Re: Questions concerning upgrading to the new firmware 1.17a January 19, 2017 10:05AM |
lasse
...So my next step is to correct the rods, and in a sort of way make the constroction more reliable and robust maybe making a "house" for the whole ormerod...
Re: Questions concerning upgrading to the new firmware 1.17a January 19, 2017 03:50PM |
lasse
But I think I found out the problem, not only probing the bed, but printing good result for le last six months since I started to use my machine not only at home but in the technical scool where I work . I should have realized it earlier. I think it has nothing to do whith software and eletronics but the (weak) mecanical construction of the Ormerod. Unlike most of other printers like Flashforge the Y movment is made by moving the bed back and forward. Ths means that the two rods below the bed must be paralell very accurate. When transporting the machine I now realize the if only fractions of a mm of this is failing, the bed will be unlevelled for much bigger size in Y direction.
I my case doing the command G30 S-1 on apart Y positions gave the trigger heights -1,360 and -2,19!
In the X direction there ar only very small differences -1,360 and -1,348 for 2 points apart from eachother. So I guess thats why the commands like M557 X10:190 Y:10:190 520 returns "Probe was not triggered during probing mode"
And I assume this explains why printings of things mat mainly goes in X direcition works fine but in Y direction makes lousy results
Im I right?
Re: Questions concerning upgrading to the new firmware 1.17a January 22, 2017 02:45PM |
