bridging
July 22, 2017 10:47AM
Hello all
Can anyone give any advice on Ormerod 2 and Simplify 3D bridging settings?
I have printed a test part reducing the bridging speed by 1 percent at a time and frankly I see little difference!
Thanks
James
Re: bridging
July 22, 2017 07:42PM
Not Ormerod 2 but 1
Here's the settings that works for me
I too find speed makes no difference and if the bridge goes to the edge of the model the perimeters will be bridging at normal printing speed anyway
If drooping layers
Stretching the filament by reducing the bridging extrusion multiplier will help
Keep the extrusion width at auto (my setting is usually 1.5 x nozzle width)
Lots of cooling
Edit:cooling for first layer to make it solid and able to carry the next layers, next layers should fused with first but not make it sag so not cooled before the bridge is able to carry the downward force from filament squeezed out (same reason for choice of low extrusion width)
If layers fail to bond at the post
adding a bit more to the bridging overlap distance will help, 0 mm vs 2 mm
A failed bonding (if a small overlap) can also be caused by a worn nozzle, if the nozzle face is worn (the flat part around the nozzle hole get too big) the filament will tend to stick and drag it of the post again
Erik
Edited 1 time(s). Last edit at 07/23/2017 05:35AM by ormerod168.
Re: bridging
July 23, 2017 08:45AM
Thanks Eric
What is your default extrusion speed ? (normal printing, not bridging )
I also saw that simplify 3D does not apply bridging settings to the perimeters. not sure if this is a bug or something that is hard to achieve ?
How often do you replace nozzles? I wouldnt think mine could be worn, but you never know, and the symptom is that the filament gets dragged if not supported.
I may just print these models with support, since they will work with it, but would be nice to get some decent bridging.
I notice it is also filament dependant. Grey Verbatim PLA gives me best bridging, but their black PLA is not as good. May be the colour additives?
Regards
James
Re: bridging
July 23, 2017 01:15PM
jamesf
The bottleneck on my system is the extruder stepper so I don't really have any default printing speed, often adjust the speed depending on perimeter and infill extrusion width, layer hight and nozzle temperature - but 50mm/s seems to be a safe zone with my normal printing setting layer hight 0.25 and width 0.75 but always babysit the first few minutes of a new printed model ready to lower the speed or raise the temp if the extruder motor stalls (knocking sound) - really should get a stepper with a bit more torque, the spring loaded extruder keep grip just fine
Maybe to avoid a visual difference in outer perimeters because of the speed change?
A stainless steel nozzle will last a long time if handled properly, I used to clean the cold nozzle with a needle file, did not think it would dig in but suddenly it refused to bridge, the now nearly flat front of the nozzle did not let go of the filament when the nozzle was reversing from post to post
Had no extra nozzle so used a lathe to set the tip back in the original angle and it bridged like it did from the start, that was the original, changed it later for a new one, did not notice any difference in flow
You can measure the flat part of the nozzle with a caliber, should be around 1mm from new, 1.5mm prolly OK, mine was more like 4mm...
Yes could be additives or difference in temperature as darker colors will absorb more radiant heat
Erik
Re: bridging
July 24, 2017 07:23AM
With ABS and no nozzle cooling, I sometimes monitor the print and apply external cooling via a small hand-held fan while it is bridging, which helps a lot.
Dave
Re: bridging
July 25, 2017 09:18AM
..and in the left corner we have...I just had to try if bridging corner to corner on the ormerod was possible, it ain't pretty but a 200mm bridge it is :-)
I attached a zip with set of stl files like the model I printed, bridging length 50 to 200mm, total length is + 30mm each - it's a simple model made in OpenScad, scad file attached
the food is a 20 x 20 x 1, post is 10 x 10 x10mm, so the bridge starts at hight 11mm and is 2mm high, e.g. print 8 layers in layer hight 0.25 or just make changes to the scad
As noted, the trick is to use a large overlap, reduce the flow a bit to stretch the filament and apply proper cooling to first bridging layer (if not, stop the print for a bit after first layer to allow it to cool down and buckle up before next layer)
Erik
open | download - bridgetest_50_to_200mm.zip (4.9 KB)
open | download - bridge.scad (322 bytes)
Re: bridging
July 25, 2017 09:26AM
Thanks Eric, glad to know it can be done.
Was that with the same settings from your previous post?
What I did notice while watching the printer and the simulation on Simplify 3D, is that the direction of the infil of the bridge is not always directly parallel to the bridge direction. The printer is then at some point attempting to attach a bridged strand to the bridge perimeter, which is often where the process seems to fail.
Your corner to corner bridge is oriented at 45 degrees across the print bed. Would this work if the bridge was along the X or Y axis and the infill orientation was still 45 degrees?
EDIT: simulating it now, it appears that on X or Y axis its ok, but a slight angle on the bridge causes what I have described above. I suppose there is no way to really eliminate this unless the slicer detects a bridge and orients the direction of the infil of the supporting layer exactly in the direction of the bridge?
James
Edited 1 time(s). Last edit at 07/25/2017 09:32AM by jamesf.
open | download - bridging.PNG (105.5 KB)
Re: bridging
July 25, 2017 09:41AM
This is quite funny.
Just reading release notes on V4 of simplify 3d. They fixed the bridging perimeter speed and angle issues we were just dealing with.
Re: bridging
July 26, 2017 05:18PM
jamesf
I did ad 3mm the overlap so total 4mm just for safety but I don't think it was necessary, it fused just fine with no pullback
Yes LOL what a silly thing, I found that out while adjusting the model 5 degrees back to make room for the glass clips, when bridging it seems to flip-flop between 45 and 90 degrees but only if the model is positioned inside those number
Yes the first bridging layer will still be right
More LOL - did not read your edit until down here, never mind :-)
Erik
Re: bridging
July 26, 2017 05:20PM
jamesf
Yes and it is released, lets see if they got it right
Erik
Re: bridging
July 26, 2017 06:29PM
ormerod168
jamesf
Erik
Not quite, still trying to turn in the middle of bridge, maybe this model is un-bridgeable, but a "need support" message would be nice, surely the software must know
Erik
Re: bridging
July 28, 2017 01:08PM
Even if it was bridgable it would be a pain to remove the bridging material later when it would be closed up.
Re: bridging
July 29, 2017 06:08AM
Darathy
Yes it would be impossible so I fixed that by placing a piece of flexible material (rubber) for the bridge to float on
Stopped the print and removed that with a pair of players, did not look pretty but was solid enough for the next layers to build on, so turned out alright
..and to be fair, Slic3r did not do any better
Erik
Re: bridging
July 31, 2017 07:22AM
That part appears to be a case of something that was not designed for FFF construction (difficult to see how the designer expected it to be made in fact). A few simple changes would make it printable with no problem, yet still have the same outward appearance and the same functionality.
Dave
