Show us your settings! November 12, 2018 06:24PM |
Re: Show us your settings! November 12, 2018 06:29PM |
Re: Show us your settings! November 13, 2018 05:11AM |
M92 X87.489 Y87.489 Z4000 E420:420 ; Set steps per mm M201 X500 Y500 Z250 E500:500 ; Accelerations (mm/s^2) M203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min) M566 X900 Y900 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min) M906 X1000 Y1200 Z1000 E1200:1200 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30
# generated by Slic3r Prusa Edition 1.41.1+win64 on 2018-11-12 at 23:49:56 [print:Ormerod 2 (0.3mm) v1.1] avoid_crossing_perimeters = 0 bottom_solid_layers = 5 bridge_acceleration = 0 bridge_angle = 0 bridge_flow_ratio = 1 bridge_speed = 40 brim_width = 0 clip_multipart_objects = 0 compatible_printers = compatible_printers_condition = complete_objects = 0 default_acceleration = 0 dont_support_bridges = 1 elefant_foot_compensation = 0 ensure_vertical_shell_thickness = 0 external_fill_pattern = rectilinear external_perimeter_extrusion_width = 0.5 external_perimeter_speed = 45 external_perimeters_first = 0 extra_perimeters = 1 extruder_clearance_height = 20 extruder_clearance_radius = 20 extrusion_width = 0.5 fill_angle = 45 fill_density = 20% fill_pattern = grid first_layer_acceleration = 0 first_layer_extrusion_width = 0.8 first_layer_height = 0.3 first_layer_speed = 50% gap_fill_speed = 10 gcode_comments = 1 infill_acceleration = 0 infill_every_layers = 1 infill_extruder = 1 infill_extrusion_width = 0.5 infill_first = 0 infill_only_where_needed = 0 infill_overlap = 25% infill_speed = 45 inherits = interface_shells = 0 layer_height = 0.3 max_print_speed = 80 max_volumetric_extrusion_rate_slope_negative = 0 max_volumetric_extrusion_rate_slope_positive = 0 max_volumetric_speed = 0 min_skirt_length = 0 notes = only_retract_when_crossing_perimeters = 1 ooze_prevention = 0 output_filename_format = [input_filename_base].gcode overhangs = 1 perimeter_acceleration = 0 perimeter_extruder = 1 perimeter_extrusion_width = 0.5 perimeter_speed = 45 perimeters = 3 post_process = print_settings_id = raft_layers = 0 resolution = 0 seam_position = aligned single_extruder_multi_material_priming = 1 skirt_distance = 2 skirt_height = 1 skirts = 1 small_perimeter_speed = 32 solid_infill_below_area = 70 solid_infill_every_layers = 0 solid_infill_extruder = 1 solid_infill_extrusion_width = 0.5 solid_infill_speed = 40 spiral_vase = 0 standby_temperature_delta = -5 support_material = 1 support_material_angle = 0 support_material_auto = 1 support_material_buildplate_only = 1 support_material_contact_distance = 0.2 support_material_enforce_layers = 0 support_material_extruder = 1 support_material_extrusion_width = 0 support_material_interface_contact_loops = 0 support_material_interface_extruder = 1 support_material_interface_layers = 3 support_material_interface_spacing = 0 support_material_interface_speed = 100% support_material_pattern = rectilinear support_material_spacing = 2.5 support_material_speed = 40 support_material_synchronize_layers = 0 support_material_threshold = 0 support_material_with_sheath = 1 support_material_xy_spacing = 50% thin_walls = 1 threads = 4 top_infill_extrusion_width = 0.5 top_solid_infill_speed = 40 top_solid_layers = 5 travel_speed = 130 wipe_tower = 0 wipe_tower_bridging = 10 wipe_tower_rotation_angle = 0 wipe_tower_width = 60 wipe_tower_x = 180 wipe_tower_y = 140 xy_size_compensation = 0 [filament:Ormerod 2 PLA 35% fan] bed_temperature = 40 bridge_fan_speed = 35 compatible_printers = compatible_printers_condition = cooling = 1 disable_fan_first_layers = 3 end_filament_gcode = "; Filament-specific end gcode \n;END gcode for filament\n" extrusion_multiplier = 1 fan_always_on = 1 fan_below_layer_time = 100 filament_colour = #FF0000 filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 25.4 filament_density = 1.24 filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 0 filament_minimal_purge_on_wipe_tower = 15 filament_notes = "" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_settings_id = "" filament_soluble = 0 filament_toolchange_delay = 0 filament_type = PLA filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 first_layer_bed_temperature = 50 first_layer_temperature = 210 inherits = max_fan_speed = 35 min_fan_speed = 3 min_print_speed = 10 slowdown_below_layer_time = 20 start_filament_gcode = "; Filament gcode\n" temperature = 210 [filament:Ormerod 2 PLA V1.1] bed_temperature = 40 bridge_fan_speed = 35 compatible_printers = compatible_printers_condition = cooling = 1 disable_fan_first_layers = 3 end_filament_gcode = "; Filament-specific end gcode \n;END gcode for filament\n" extrusion_multiplier = 1 fan_always_on = 1 fan_below_layer_time = 100 filament_colour = #FF0000 filament_cooling_final_speed = 3.4 filament_cooling_initial_speed = 2.2 filament_cooling_moves = 4 filament_cost = 25.4 filament_density = 1.24 filament_diameter = 1.75 filament_load_time = 0 filament_loading_speed = 28 filament_loading_speed_start = 3 filament_max_volumetric_speed = 0 filament_minimal_purge_on_wipe_tower = 15 filament_notes = "" filament_ramming_parameters = "120 100 6.6 6.8 7.2 7.6 7.9 8.2 8.7 9.4 9.9 10.0| 0.05 6.6 0.45 6.8 0.95 7.8 1.45 8.3 1.95 9.7 2.45 10 2.95 7.6 3.45 7.6 3.95 7.6 4.45 7.6 4.95 7.6" filament_settings_id = "" filament_soluble = 0 filament_toolchange_delay = 0 filament_type = PLA filament_unload_time = 0 filament_unloading_speed = 90 filament_unloading_speed_start = 100 first_layer_bed_temperature = 50 first_layer_temperature = 210 inherits = max_fan_speed = 20 min_fan_speed = 3 min_print_speed = 10 slowdown_below_layer_time = 20 start_filament_gcode = "; Filament gcode\n" temperature = 210 [printer:Ormerod 2 v1.2] bed_shape = 0x0,200x0,200x200,0x200 before_layer_gcode = between_objects_gcode = cooling_tube_length = 5 cooling_tube_retraction = 91.5 default_filament_profile = "" default_print_profile = deretract_speed = 0,0 end_gcode = G10 P0 R0 S0 ; Set tool 0 operating and standby temperatures\nG10 P1 R0 S0 ; Set tool 1 operating and standby temperatures\nG28 X0 ; home X axis\nM84 ; disable motors\nM140 S0 ;\nM140 S-273\n\n extra_loading_move = -2 extruder_colour = #0000FF;#FF0000 extruder_offset = 0x0,0x0 gcode_flavor = marlin host_type = duet inherits = layer_gcode = machine_max_acceleration_e = 500,250 machine_max_acceleration_extruding = 500,250 machine_max_acceleration_retracting = 500,250 machine_max_acceleration_x = 500,250 machine_max_acceleration_y = 500,250 machine_max_acceleration_z = 250,250 machine_max_feedrate_e = 1200,600 machine_max_feedrate_x = 6000,3000 machine_max_feedrate_y = 6000,3000 machine_max_feedrate_z = 180,90 machine_max_jerk_e = 120,60 machine_max_jerk_x = 900,450 machine_max_jerk_y = 900,450 machine_max_jerk_z = 12,6 machine_min_extruding_rate = 0,0 machine_min_travel_rate = 0,0 max_layer_height = 0.4,0.4 max_print_height = 170 min_layer_height = 0.07,0.07 nozzle_diameter = 0.5,0.5 parking_pos_retraction = 92 print_host = 192.168.0.26 printer_model = printer_notes = printer_settings_id = printer_variant = printer_vendor = printhost_apikey = printhost_cafile = remaining_times = 0 retract_before_travel = 2,2 retract_before_wipe = 0%,0% retract_layer_change = 1,1 retract_length = 2,2 retract_length_toolchange = 10,10 retract_lift = 0,0 retract_lift_above = 0,0 retract_lift_below = 0,0 retract_restart_extra = 0,0 retract_restart_extra_toolchange = 0,0 retract_speed = 40,40 serial_port = serial_speed = 250000 silent_mode = 1 single_extruder_multi_material = 0 start_gcode = M201 X500 Y500 Z250 E500:500 ; Accelerations (mm/s^2)\nM203 X15000 Y15000 Z100 E3600 ; Maximum speeds (mm/min)\nM566 X900 Y900 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min)\n\nG28 ; home all axes\nG1 Z1 F5000 ; lift nozzle toolchange_gcode = use_firmware_retraction = 0 use_relative_e_distances = 1 use_volumetric_e = 0 variable_layer_height = 1 wipe = 0,0 z_offset = 0
Re: Show us your settings! November 13, 2018 05:16AM |
Re: Show us your settings! November 14, 2018 09:36AM |
Re: Show us your settings! November 14, 2018 12:40PM |
