More mesh levelling issues November 23, 2018 08:35AM |
cheeseandham
This is my last mesh with lokbuild stuck on my aluminium plate.
If you're wondering about the flatness of my aluminium plate, it is Aluminium ACP 5080 6mm, with a base tolerance is 0.1mm across a length of 3.3m x width 2.05m.
Then it was cut to 203mm x 203mm and ground flat to a tolerance of 0.4 microns.
It's pretty flat.
dc42
That pattern indicates that there is a problem with your X axis. At low X values, the trigger height is depending on the direction in which the X axis last moved.
; Configuration file for Duet WiFi (firmware version 1.21) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool on Mon Oct 29 2018 11:26:08 GMT+0000 (Greenwich Mean Time) ; General preferences M111 S0 ; Debugging off G21 ; Work in millimetres G90 ; Send absolute coordinates... M83 ; ...but relative extruder moves ; Network M550 POrmerod 2 DuetWifi ; Set machine name M552 S1 ; Enable network ;*** Access point is configured manually via M587 M586 P0 S1 ; Enable HTTP M586 P1 S0 ; Disable FTP M586 P2 S0 ; Disable Telnet ; Drives M569 P0 S0 ; Drive 0 goes backwards M569 P1 S1 ; Drive 1 goes forwards M569 P2 S1 ; Drive 2 goes forwards M569 P3 S1 ; Drive 3 goes forwards M569 P4 S1 ; Drive 4 goes backwards M350 X16 Y16 Z16 E16:16 I1 ; Configure microstepping with interpolation M92 X87.489 Y87.489 Z4000 E420:420 ; Set steps per mm ;M201 X500 Y500 Z250 E250:250 ; Accelerations (mm/s^2) was E500:E500 ;M203 X15000 Y15000 Z180 E3600:3600 ; Maximum speeds (mm/min) ;M566 X900 Y900 Z12 E120:120 ; Set maximum instantaneous speed changes (mm/min) M566 X900.00 Y900.00 Z12.00 E120.00 ; Set maximum instantaneous speed changes (mm/min) (mesh diagnosis) M203 X6000.00 Y6000.00 Z180.00 E1200.00 ; Set maximum speeds (mm/min) (mesh diagnosis) M201 X500.00 Y500.00 Z250.00 E250.00 ; Set accelerations (mm/s^2) (mesh diagnosis) M906 X1000 Y1200 Z1000 E1200:1200 I30 ; Set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y-15 Z0 S1 ; Set axis minima (adjust to make X=0 the edge of the bed) M208 X200 Y200 Z160 S0 ; Set axis maxima ; Endstops M574 Y1 S1 ; Set active high endstops ; M574 X0 Z0 S2 ; Set active low endstops (default) ; Z-Probe M574 X1 Z1 S2 ; Set endstops controlled by probe M558 P1 X1 Y0 Z1 H5 F120 T6000 ; Set Z probe type to unmodulated, the axes for which it is used and the dive height + speeds ; ************* G31 P500 X-33 Y3 Z1.26 ; Set Z probe trigger value, offset and trigger height ; ************* ;Orthogonal Axis Compensation ;M556 S0 X0 Y0 Z0 ; Set orthogonal axis compensation parameters M557 X0:160 Y15:185 S20 ; Define mesh grid ; Heaters M570 H1 T25 ; Permitted temperature excursion from the setpoint for this heater (30 degrees C) M570 H2 T25 ; Permitted temperature excursion from the setpoint for this heater (30 degrees C) M307 H0 B0 S1.00 ; Disable bang-bang mode for the bed heater and set PWM limit M305 P0 T10000 B3988 C0 R4700 ; Set thermistor + ADC parameters for heater 0 M143 H0 S120 ; Set temperature limit for heater 0 to 120C M305 P1 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 1 M143 H1 S280 ; Set temperature limit for heater 1 to 280C M305 P2 T100000 B4138 C0 R4700 ; Set thermistor + ADC parameters for heater 2 M143 H2 S280 ; Set temperature limit for heater 2 to 280C ; Fans M106 P0 S0 I0 F500 H-1 ; Set fan 0 value, PWM signal inversion and frequency. Thermostatic control is turned off ;M106 P1 S1 I0 F500 H1:2 T45 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on ;M106 P2 S1 I0 F500 H1:2 T45 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P1 S0 I0 H-1 ; Set fan 1 value, PWM signal inversion and frequency. Thermostatic control is turned on M106 P2 S0 I0 H-1 ; Set fan 2 value, PWM signal inversion and frequency. Thermostatic control is turned on ; Tools M563 P0 D0 H1 ; Define tool 0 G10 P0 X0 Y0 Z0 ; Set tool 0 axis offsets G10 P0 R0 S0 ; Set initial tool 0 active and standby temperatures to 0C M563 P1 D1 H2 ; Define tool 1 G10 P1 X18.87 Y0 Z0 ; Set tool 1 axis offsets G10 P1 R0 S0 ; Set initial tool 1 active and standby temperatures to 0C ; Automatic power saving M911 S10 R11 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; Set voltage thresholds and actions to run on power loss ; Custom settings T0 ; select first hot end M207 S3.7 F2400 Z0 ; firmware retraction ; Miscellaneous M501 ; Load saved parameters from non-volatile memory
M122 === Diagnostics === RepRapFirmware for Duet 2 WiFi/Ethernet version 2.02RC3(RTOS) running on Duet WiFi 1.02 or later Board ID: 08DGM-95BLL-N6PSS-6JKD2-3SJ6M-10UMJ Used output buffers: 3 of 20 (11 max) === RTOS === Static ram: 28532 Dynamic ram: 98884 of which 0 recycled Exception stack ram used: 400 Never used ram: 3256 Tasks: NETWORK(ready,328) HEAT(blocked,1232) MAIN(running,3540) Owned mutexes: WiFi(NETWORK) === Platform === Last reset 00:33:21 ago, cause: software Last software reset at 2018-11-23 13:00, reason: User, spinning module GCodes, available RAM 3376 bytes (slot 3) Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0xffffffff Task 0x4e49414d Error status: 0 Free file entries: 10 SD card 0 detected, interface speed: 20.0MBytes/sec SD card longest block write time: 12.7ms, max retries 0 MCU temperature: min 33.8, current 37.1, max 38.6 Supply voltage: min 12.3, current 12.4, max 12.5, under voltage events: 0, over voltage events: 0 Driver 0: standstill, SG min/max 0/285 Driver 1: standstill, SG min/max 0/223 Driver 2: standstill, SG min/max 0/309 Driver 3: standstill, SG min/max not available Driver 4: standstill, SG min/max not available Date/time: 2018-11-23 13:33:27 Cache data hit count 4294967295 Slowest loop: 42.80ms; fastest: 0.07ms === Move === Hiccups: 0, StepErrors: 0, LaErrors: 0, FreeDm: 240, MinFreeDm: 236, MaxWait: 166379ms, Underruns: 0, 0 Scheduled moves: 369, completed moves: 369 Bed compensation in use: mesh Bed probe heights: 0.000 0.000 0.000 0.000 0.000 === Heat === Bed heaters = 0 -1 -1 -1, chamberHeaters = -1 -1 Heater 1 is on, I-accum = 0.0 === GCodes === Segments left: 0 Stack records: 2 allocated, 0 in use Movement lock held by null http is idle in state(s) 0 telnet is idle in state(s) 0 file is idle in state(s) 0 serial is idle in state(s) 0 aux is idle in state(s) 0 daemon is idle in state(s) 0 queue is idle in state(s) 0 autopause is idle in state(s) 0 Code queue is empty. === Network === Slowest loop: 14.12ms; fastest: 0.00ms Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0) Telnet(0) HTTP sessions: 2 of 8 - WiFi - Network state is running WiFi module is connected to access point Failed messages: pending 0, notready 0, noresp 0 WiFi firmware version 1.21 WiFi MAC address 2c:3a:e8:0b:09:f7 WiFi Vcc 3.41, reset reason Turned on by main processor WiFi flash size 4194304, free heap 12224 WiFi IP address 192.168.0.26 WiFi signal strength -58dBm, reconnections 0, sleep mode modem Socket states: 0 0 0 0 0 0 0 0
Re: More mesh levelling issues November 23, 2018 11:02AM |
Re: More mesh levelling issues November 23, 2018 11:10AM |
Re: More mesh levelling issues November 23, 2018 11:34AM |
Re: More mesh levelling issues November 23, 2018 01:30PM |
Re: More mesh levelling issues November 23, 2018 02:03PM |
Re: More mesh levelling issues November 23, 2018 02:25PM |
cheeseandham
I'll take a close look at the cabling and the PTFE tubing, and see if it is doing something.
Re: More mesh levelling issues November 23, 2018 02:53PM |
Re: More mesh levelling issues November 23, 2018 02:54PM |
dc42
My Ormerod is currently decommissioned due to lack of bench space, but I'll try to extract a height map from the SD card and post it tomorrow.
Re: More mesh levelling issues November 23, 2018 06:24PM |
Re: More mesh levelling issues November 23, 2018 06:36PM |
Re: More mesh levelling issues November 23, 2018 06:40PM |
ormerod168
The PTFE tube _is_ doing something, mostly with the acrylic rib, less with the aluminium one, but still via the springiness of the plastic parts between x-runner- bearing and metal part of hotend
[forums.reprap.org]
Erik
Re: More mesh levelling issues November 23, 2018 06:56PM |
Re: More mesh levelling issues November 23, 2018 07:10PM |
Re: More mesh levelling issues November 24, 2018 10:10AM |
Re: More mesh levelling issues November 24, 2018 10:58AM |
Re: More mesh levelling issues November 24, 2018 11:18AM |
Re: More mesh levelling issues November 24, 2018 12:02PM |
dc42
I've seen elsewhere in these forums that those in the know advise against using linear bearings. Linear rails are recommended instead.
Re: More mesh levelling issues November 24, 2018 12:06PM |
Re: More mesh levelling issues November 24, 2018 07:16PM |
dc42
That height map shows 3 features:
1. The wave. This suggests that either the height or the angle of the print head varies with X position.
2. Ridges and valleys in the X direction on alternate rows of probe points. This indicates that the height or angle of the print carriage depends a little on whether you approach the point in the +X or -X direction.
Re: More mesh levelling issues November 25, 2018 10:47AM |
cheeseandham
ormerod168
[forums.reprap.org]
Erik
Thank you Erik. So to mitigate this in your opinion what should be done?
One idea is to increase the size of the bowden as much as reasonably possible, but I'll be very interested to hear anything else.
Re: More mesh levelling issues January 01, 2019 03:49PM |
